nct commands gives error
kbarve
I am exploring the nct tool for NSO upgrade procedure.
I referred the admin and man NSO doc. I am facing issue with nct commands, not sure if any configuration is needed to use nct commands
$ nct check --hostsfile hostsfile
ERROR : internal error
error: function_clause
[{nct_ssh,run,
          ["/opt/ncs/current/bin/ncs --version","127.0.0.1","2024","admin",
           [{password,"admin"}],
           infinity,0],
          [{file,"nct_ssh.erl"},{line,66}]},
{nct_lib,ssh,3,[{file,"nct_lib.erl"},{line,202}]},
{nct_check,request,3,[{file,"nct_check.erl"},{line,266}]},
{nct_check,'-request/3-fun-0-',4,[{file,"nct_check.erl"},{line,135}]},
{lists,foldr,3,[{file,"lists.erl"},{line,1261}]},
{lists,map,2,[{file,"lists.erl"},{line,1224}]},
{nct_check,run,1,[{file,"nct_check.erl"},{line,102}]},
{escript,run,2,[{file,"escript.erl"},{line,747}]}]
$ nct packages --hostsfile hostsfile
Package Info at 127.0.0.1:"8888"
  REST ERROR : {error,{failed_connect,[{to_address,{"127.0.0.1",8888}},
                        {inet,[inet],econnrefused}]}}
$ nct ssh-cmd -c 'ls' --hostsfile hostsfile
[{nct_ssh,run,
          ["ls","127.0.0.1","2024","admin",[{password,"admin"}],infinity,0],
{nct_ssh_cmd,request,2,[{file,"nct_ssh_cmd.erl"},{line,97}]},
{nct_ssh_cmd,run,1,[{file,"nct_ssh_cmd.erl"},{line,76}]},
{escript,run,2,[{file,"escript.erl"},{line,747}]},
{escript,start,1,[{file,"escript.erl"},{line,277}]},
{init,start_it,1,[]}]
$ cat hostsfile
{"127.0.0.1", [{ssh_user,"admin"},
           {ssh_pass, "admin"},
           {ssh_port, "2024"},
           {rest_user,"admin"},
           {rest_pass, "admin"},
           {rest_port, "8080"}]}.      (Tried 8888 ports as well)
cat ncs.conf
<ssh>
  <enabled>true</enabled>
  <ip>0.0.0.0</ip>
  <port>2024</port>
</ssh>
<transport>
  <ssh>
    <ip>0.0.0.0</ip>
    <port>2022</port>
</ssh>
kbarve
Now I am getting below error now.
Please let me know if I am missing anything in configuration.
Tried on same m/c
KBARVE-M-J2Y4:ncs-run kbarve$ nct check --hostsfile hostsfile
nct_lib(792): HTTP Request = "http://127.0.0.1:8080/api/operational/ncs-state/ha"
nct_lib(803): HTTP(401) Reply = {"HTTP/1.1",401,"Unauthorized"}
nct_lib(804): HTTP(401) Reply Body = <<"\n<html>\n<body>\n<h1>401 authentication needed</h1></body></html>">>
nct_lib(823): xmerl_scan error : function_clause
nct_lib(199): SSH /home/ec2-user/ncs-run/current/bin/ncs --version
nct_ssh(97): Address = "127.0.0.1", Error = "Install alg failed"
nct_lib(208): SSH ERROR = "Install alg failed"
nct_ssh(148): Address: "127.0.0.1" , Error = "Install alg failed"
nct_lib(304): NETCONF ERROR = "Install alg failed"
nct_lib(792): HTTP Request = "http://127.0.0.1:8080/api"
nct_lib(199): SSH df -h /var /opt
nct_lib(199): SSH sudo -v
nct_lib(199): SSH ssh
ALL Check to 127.0.0.1:2024
SSH ERROR : Install alg failed
SSH+SUDO ERROR : failed to run 'sudo -v'
DISK-USAGE ERROR : failed to run 'df -h /var /opt'
REST OK
NETCONF ERROR : failed to run netconf
NCS-VSN ERROR : failed to run '/home/ec2-user/ncs-run/current/bin/ncs --version'
HA ERROR : ha call failed
KBARVE-M-J2Y4:ncs-run kbarve$ cat hostsfile
{"127.0.0.1", [
                    {cmd,"all"},
                    {host,"127.0.0.1"},
                    {verbose,5},
                    {rest_pass,"admin"},
                    {ssh_pass,"admin"},
                    {ssh_port,2024},
                    {install_dir,"/home/ec2-user/ncs-run"},
                    {ssh_user,"admin"},
                    {ssh_cmd,"ssh"},
                    {disk_limit,80},
                    {concurrent," true"},
                    {groupoper,"or"},
                    {timeout,infinity},
                    {progress,false},
                    {ssh_timeout,infinity},
                    {rest_user,"ec2-user"},
                    {rest_port,8080},
                    {rest_ssl,"false"},
                    {netconf_user,"admin"},
                    {netconf_port,2022},
                    {netconf_proto,"ssh"}
Tried on a separate m/c
[ec2-user@ip-20-20-10-202 ncs-run]$ nct check --hostsfile hostsfile
nct_lib(792): HTTP Request = "http://20.20.10.121:8080/api/operational/ncs-state/ha"
nct_ssh(97): Address = "20.20.10.121", Error = "Install alg failed"
nct_ssh(148): Address: "20.20.10.121" , Error = "Install alg failed"
nct_lib(792): HTTP Request = "http://20.20.10.121:8080/api"
ALL Check to 20.20.10.121:2024
REST OK
cat ncs-run/hostsfile
{"20.20.10.121", [
                    {cmd,"all"},
                    {host,"20.20.10.121"},
                    {verbose,5},
                    {ssh_pass,"admin"},
                    {ssh_port,2024},
                    {ssh_user,"admin"},
                    {ssh_cmd,"ssh"},
                    {disk_limit,80},
                    {groupoper,"or"},
                    {timeout,infinity},
                    {progress,false},
                    {rest_port,8080},
                    {rest_ssl,"false"},
kbarve
Now NCT for rest api is working fine.
Can someone plz help to resolve this error?
[ec2-user@ip-20-20-10-202 ncs-run]$ nct ssh-cmd -c 'sudo id'  --hostsfile hostsfile -vvvv
nct_lib(125): Opts=[{cmd,"sudo id"},
                    {hostsfile,"hostsfile"},
                    {verbose,4},
                    {groupoper,"or"},
                    {timeout,infinity},
                    {progress,false},
                    {ssh_user,"ec2-user"},
                    {ssh_port,22},
                    {ssh_timeout,infinity}] , Crap=[]
nct_ssh_cmd(64): Updated Opts=[{hosts_opts,
                                   [{"20.20.10.121",
                                     [{cmd,"all"},
                                      {verbose,5},
                                      {ssh_pass,"admin"},
                                      {ssh_port,2024},
                                      {install_dir,"/home/ec2-user/ncs-4.3.1"},
                                      {ssh_user,"admin"},
                                      {ssh_cmd,"ssh"},
                                      {disk_limit,80},
                                      {groupoper,"or"},
                                      {timeout,infinity},
                                      {progress,false},
                                      {rest_port,8080},
                                      {rest_ssl,"false"},
                                      {netconf_proto,"ssh"}]}]},
                               {cmd,"sudo id"},
                               {verbose,4},
                               {groupoper,"or"},
                               {timeout,infinity},
                               {progress,false},
                               {ssh_port,22},
nct_lib(199): SSH all
SSH command to 20.20.10.121:2024
