Need SNMP Based NED
skonni
I am looking SNMP NEDs.
My Scenario is, I have to read/get the data from the device using mib oid's.
Can some one please help to check above scenerio.
Also, I am looking rest api request to get the device information using mib id's
Suresh Konni.
Jan Lindblad
First you need to build an SNMP NED for your device. Have a look at the "NSO Device Manager" section in the NSO User's Guide, then "NSO Packages" in the NSO Development Guide.
To understand how you manage the NSO system, and all of the devices it manages, using RESTCONF, see "The RESTCONF API" in the NSO Northbound Guide. Should you need a more powerful API, you might want to consider NETCONF (standard) or JSON-RPC (proprietary).
Jan Lindblad
