NetSim devices oboarding issue
pvagu
Below is the error I have seen while deploying the VNFD. Please let me know if Iam missing something while using auth groups.
Error: Failed to fetch ssh host keys for SANJOSE-SAE_TEN
Attached screenshot for your reference.
kiran kotari
1. Can you check is your vm alive and reachable from NSO. (In the image I see vm-alive not-reached)
2. if you VM alive and reachable then try fetch-ssh-hostkeys if your are still facing an issue, then check your auth-groups.
Note:- Provide more informative data to know about the issue. The Screenshot doesn't give information why it failed and what was the scenario etc.
Thanks for your response Kiran. I was trying to do "VNFD CSR deployment" and hit with above "Failed to fetch ssh host keys for SANJOSE-SAE_TEN" error. Issue got fixed after extracting the IOS package. I followed the below steps.
1. Exit from NSO CLI shell
2. cd /usr/shared/sae
3. cd packages
4. tar xvf ncs-5.2.2.2-cisco-ios-cli-6.49.tar.gz
5. rm ncs-5.2.2.2-cisco-ios-cli-6.49.tar.gz
6. rm -rf ./state/packages-in-use.cur/
7. IS_NETSIM=true ncs --with-package-reload-force
Hi Praharsha,
There was no netsim device running on your vm/docker, which leaded this issue. Here are the useful commands to create and add device to NSO.
ncs-netsim add-device <ned-location> <device-name>
ncs-netsim start <device-name>
ncs-netsim ncs-xml-init <device-name> > <filename.xml>
ncs_load -l -m <filename.xml>
ncs-cli -c -u admin
devices device <device-name> ssh fetch-host-keys
devices device <device-name> sync-from
-Kiran
