Netsim does not have Network Element Driver registered
Hey NSO Community!
I am hitting an issue with setting up a CI system with NSO and Netsims for testing. I am running NSO in a container that wcan be run locally or on a jenkins server to execute unittests and package validation.
I create and add the netsims by:
1. ncs-netsim create-network cisco-ios 1 dummy
2. ncs-netsim add-device ios-device-0 cisco-ios
3. ncs-setup .
4. ncs
Then run a script to execute "sync-from-file PATH/device_config/ios-device-0-config.txt" on the netsim to get config from a text file.
The issue i have, is that when trying to use live status exec actions or make config changes on the added netsims I get the error:
"_ncs.error.Error: item does not exist (1): Device ios-device-0 does not have a Network Element Driver registered "
I have confirmed that the netsim has a ned registered in device settings.
again, the odd thing is it all works when i run the container on a jenkins server, but not when locally on MacOS. The hope with the container was the ability o have consistency between the local dev, CICD test env, and production env.
Thoughts on the cause of the does not have a Network Element Driver registered  issue?
Thanks!
Brandon
update:
running a ncs --status after start shows:
Loaded packages:
[2018-04-24 09:24:48,577][heighliner.lib.container][INFO] : cisco-ios:
[2018-04-24 09:24:48,577][heighliner.lib.container][INFO] : Version: 5.8.3 Status: error
[2018-04-24 09:24:48,578][heighliner.lib.container][INFO] : Info: [LOAD_PACKAGE[GC overhead limit exceeded]]
any insight into how to adjust or address the GC overhead limit exceeded? Or what the GC limit is?
thanks!
Update:
issue resolved by increasing the docker memory allocation on the local mac
