netsim multi-ned network issue
previousqna
Level 8
Level 8
Hi All,
I am trying to create a netsim network of ios and iosxr devices, however nso is only able to see devices of one type.
I am using nso 4.2 and create an iosxr network using ncs-netsim create-network command. Next I use the add-to-network command and add ios devices followed by ncs-setup and ncs to start nso.
When I connect to the devices I only see the iosxr devices which I created via the ‘create-network’ option.
Not sure why I don’t see the ios devices in nso even though they are visible in the netsim directory and I can cli-i connect to them?
And better, with NSO 4.2, you should be using NSO projects:
ROGAGLIA-M-M0VW:~ rogaglia$ ncs-project —help
previousqna
Level 8
Level 8
Looking at the netsim man page you should be doing the following to load the netim devices into the ncs db
$ ncs-netsim ncs-xml-init > devices.xml
$ ncs_load -l -m devices.xml
Thanks, that works.
I was following the getting started guide which doesn’t work for this case.
