Northbound NETCONF Quick Question
tpomerhn
This is probably a basic question so I apologize if it's something I should have figured out on my own, but I can't seem to find a definitive reason why ncclient and netconf-console are different in how they handle the XML payload. I have some scripts that work fine adding/deleting devices through the RESTCONF API, but was looking for a password-less solution like NETCONF to accomplish the same. I can get the following XML, when output to a file and passed to netconf-console using the --edit-config command, to run properly:
<devices xmlns="http://tail-f.com/ns/ncs">
<device>
<name>router1</name>
<address>10.1.1.1</address>
<port>22</port>
<authgroup>general</authgroup>
<device-type>
<cli>
<ned-id>cisco-ios-cli-6.46:cisco-ios-cli-6.46</ned-id>
<protocol>ssh</protocol>
</cli>
</device-type>
<state>
<admin-state>unlocked</admin-state>
</state>
</device>
</devices>
I can write this to a file and send it using netconf-console, but I'd rather use ncclient and pass this all in memory as a variable to the manager edit_config function instead and not have to write temporary xml files. But if I put the above code into a variable and attempt to send it via ncclient:
NewDeviceXML=''' <the exact code from above> '''
from
 ncclient import manager
with manager.connect(host=nsohost, port=2022username="automate", \
    hostkey_verify=Falsekey_filename="/opt/automate/automate"as conn:
        conn.edit_config(target='running'config=NewDeviceXML)
All I get are "Element [x] does not meet requirement" messages, where x can be anything. I've tried tinkering by adding a <?xml first line, adding <config> wrappers, all kinds of things and none of them work. It's something about how ncclient handles the XML payload versus netconf-console and I'm missing something.
If someone could point out my (probably blatantly obvious to the non-NETCONF-ncclient-novice) error I would appreciate it. :)
perander
There are several possible solutions to this question.
In order to get the NewDeviceXML <device> payload to work with the supplied
ncclient code, it needs to be wrapped inside <config> like so:
<config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<device xmlns="...">
</device>
</config>
Secondly, it's possible to use External Token Authentication with RESTCONF, which
would enable password less access. In short, configure
/ncs-config/aaa/external-validation according to access requirements in ncs.conf
and supply the X-Auth-Token header to RESTCONF requests.
It's also possible to use External Authentication with RESTCONF, so a custom
authentication mechanism can be tailored. Enable by configuring
/ncs-config/aaa/external-authentication in ncs.conf.
Finally, it's possible to pipe the payload as a multiline string directly to netconf-console,
without storing it in an intermediate file:
$ echo '<devices xmlns="http://tail-f.com/ns/ncs">
> <device>
> <port>22</port>
> <device-type>
> <cli>
> </cli>
> </device-type>
> <state>
> </state>
> </device>
> </devices>' | netconf-console --edit-config -
perander
</device>
</config>
> <device>
> <port>22</port>
> <device-type>
> <cli>
> </cli>
> </device-type>
> <state>
> </state>
> </device>
Thanks so much - I had tried with just <config> at the start before, and it failed the XML parsing checks. Now that it has a proper xmlns, it runs great. I also like your pipe solution but obviously getting ncclient to go is also extremely helpful.
I'll look into the RESTCONF using an X-Auth-Token but for now, simple NETCONF using key-based SSH is a good API for me to use to programmatically add/delete devices (instead of using direct CLI on the NSO instance).
Thanks again, for both a quick and thorough response!
If you are looking for some basic examples for using the RESTCONF API, we have created a postman collection on the NSO Developer Github Org:
https://github.com/NSO-developer/cisco-nso-postman
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
