NSO API's - CLI output
vikhegde
We are looking for API’s to talk to NSO collector in CLI format.
We tried the available API’s but output is in XML format.
For example, when we make a NSO REST API call to get the configuration of a device managed by NSO using the URL below the response is in XML format.
Is there a way to get the response in the format as displayed on the device CLI (e.g. show running-config)?
http://10.126.78.221:8080/api/running/devices/device/c0/config
frjansso
AFAIK you can only get the configuration as XML (default) or JSON (Accept: application/vnd.yang.data+json) via REST.
frjansso
