NSO: building NED errors Yang model 1.0 vs 1.1
nrajan
Hello All,
We are using NSO 6.1 for our project, and working on building ned - few of the errors we get, appears to be related to yang 1.0 like -
an identifier must not start with [xX][mM][lL] in YANG version 1
or, leaf type “empty” cannot be part of union
These errors should not be coming if NSO 6.1 was complaint with RFC 7950 (Yang 1.1).
Is there a way to make NSO 6.1, complaint with 1.1?
jvikman
Hi nrajan,
There's no support for empty leafs in unions at the moment but we have it in our plan.
Can you describe more in detail what you're trying to do with the identifier? Are you using the statement "yang-version 1.1"?
BR,
Johan
snovello
If the yang modulke contains a yang 1.1 model, so it includes the line
yang-version 1.1;
than NSO will treat it as a yang 1.1 version model. Otherwise it will treat it as a yang 1.0 module. The RFC requires that.
With that change you will see the xmlXML identifier issues go.
However empty types in unions are not supported in nso 6.1
For workarounds, you could edit you model by using a type like
type string {
length 0;
nrajan
Thank you @snovello and @jvikman ..This helps.
