NSO device out of sync time
abhinavr5289
I have some questions regarding the NSO device out of sync
After how much time, will NSO declare the device as out of sync?
do NSO check/compare config for the device before any new config did from NSO ? and then it decides if the device is in-sync or not?
is there any config in NSO to increase time?
do we need to perform sync-from to all devices after every login attempt to NSO?i
Abhinav R
KJ Rossavik
NSO will only declare a device out of sync if it has attempted an operation (either a transaction or a check-sync) towards the device. So time is not a factor
Yes, the first step in a transaction is to check if the device config is in sync with the config held in CDB
No, because time does not play any role in this
No, just carry out the transaction and if it fails because of out-of-sync, then you deal with it then as an exception. In the ideal case NSO is the only thing (system or person) changing the configuration of the device, so it is always in sync. However, reality is often more messy than the ideal. I have described some scenarios like this here: https://community.cisco.com/t5/nso-developer-hub-blogs/deploying-nso-in-brownfield-networks/ba-p/4129605
KJ Rossavik
NSO will check sync as part of the next transaction towards the device (unless you explicitly skip check sync)
Hi @KJ Rossavik ,
What is the criteria for NSO to declare any Device out of sync? how much changes difference or any time between device and NSO?
Abhinav R
KJ Rossavik
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
