NSO Docker package reload hanging with cisco-ios
Sean Chandler
Hi Folks,
Since version 3.4 or so I have been using NSO in a docker container to great success.  A recent issue with cisco-ucs ned caused me to try upgrading to latest 4.5.3 (also tried 4.5.2) and discovered that package loading would hang on cisco-ios.  Removing this package alleviates the issue entirely.  During the probelm 'show packages package oper-status' shows the java vm uninitialized.  Looking in the log ncs-java-vm.log I see the following:
<INFO> 30-Jan-2018::14:05:41.921 NcsMain JVM-Launcher: - LOADING PACKAGE ["cisco-asa"] -->
<WARN> 30-Jan-2018::14:05:42.195 ResourceManager JVM-Launcher: - Resource annotated field :ASANedCli::mm already set, no resource injection performed
<WARN> 30-Jan-2018::14:05:42.195 ResourceManager JVM-Launcher: - Resource annotated field :ASANedCli::cdb already set, no resource injection performed
<INFO> 30-Jan-2018::14:05:42.195 NcsMain JVM-Launcher: - LOADING PACKAGE ["cisco-asa"] --> LOADED
<INFO> 30-Jan-2018::14:05:42.195 NcsMain JVM-Launcher: - DONE COMMAND --> LOAD_PACKAGE
<INFO> 30-Jan-2018::14:05:42.196 NcsMain JVM-Launcher: - READ SOCKET =>
<INFO> 30-Jan-2018::14:05:42.196 NcsMain JVM-Launcher: -  <= GOT LOAD_PACKAGE
<INFO> 30-Jan-2018::14:05:42.197 NcsMain JVM-Launcher: - FOUND TYPE: callback
<INFO> 30-Jan-2018::14:05:42.197 NcsMain JVM-Launcher: - FOUND TYPE: ned
<INFO> 30-Jan-2018::14:05:42.198 NcsMain JVM-Launcher: - LOADING PACKAGE ["cisco-ios"] -->
Has anyone run into this issue in general use?  One caveat I have is that I have modified /etc/init.d slightly (below) but everything else I see appears the same.
root@innopod-ncs:/src# cat package-links.sh
#!/bin/bash
cd /var/opt/ncs/packages/
for d in `find /opt/ncs/packages/ -maxdepth 1 -type d`; do
    ls $d/README > /dev/null 2>&1
    if [ $? == 0 ]; then
        echo "Adding link from $d to /var/opt/ncs/packages/"
        ln -sf $d
    fi
done
root@innopod-ncs:/src# diff ncs /etc/init.d/ncs
38,43d37
< ARG=$2
< case "$ARG" in
<     daemon)
<         daemon='--foreground'
< esac
48c42
<         $ncs --cd ${rundir} ${heart} ${conf} ${daemon}
77,78d70
<         /src/package-links.sh
83c75
88,89d79
96c86
frjansso
This is most certainly a memory issue where the JVM is killed.
There can be two (AFAIK) reasons for this
JVM limit
You probably have to up the memory limit for NSO's JVM, please pass this environment var to your container: NCS_JAVA_VM_OPTIONS=-Xmx2G
Container limit
If pure Docker, see the "--memory bytes" flag.
If k8s, see "resources" for the pod, e.g.:
          resources:
            limits:
              memory: 4Gi
            requests:
              memory: 256Mi
frjansso
JVM limit
Container limit
          resources:
            limits:
              memory: 4Gi
            requests:
              memory: 256Mi
Instant fix!  Thanks so much.  I would never have figured that out on my own   4.5.3 is now working perfectly.
-s
