NSO generate error when ha-raft create-cluster
BasharAziz
NSO generate error when ha-raft create-cluster, I don't know from where ncsd@ is coming! and is added in the front of the hostname
admin@ncs# show ha-raft
ha-raft status role leader
ha-raft status leader nso01.example.com
ha-raft status member [ nso01.example.com nso02.example.com nso03.example.com ]
ha-raft status connected-node [ nso02.example.com nso03.example.com ]
ha-raft status local-node nso01.example.com
SERIAL NUMBER                             EXPIRATION DATE            FILE PATH
xxxx                                              2033-07-07T10:27:52+00:00  /etc/ncs/ssl/cert/nso01.crt
xxxx                                             2033-07-07T08:09:57+00:00  /etc/ncs/ssl/cert/ca.crt
ha-raft status log current-index 0
ha-raft status log applied-index 0
ha-raft status log num-entries 11
NODE                STATE              INDEX  LAG
ncsd@nso02.example.com  requires-snapshot  0      0
ncsd@nso03.example.com  requires-snapshot  0      0
on the seed node:
ha-raft status role stalled
ha-raft status connected-node [ nso01.example.com nso03.example.com ]
ha-raft status local-node nso02.example.com
xxxx                                               2033-07-07T10:27:39+00:00  /etc/ncs/ssl/cert/nso02.crt
ha-raft status log num-entries 0
admin@ncs#
info message:
<INFO> 10-Jul-2023::10:31:45.441 9ccc7c1bdb1d ncs[152]: Leader[raft_server_ha_raft_1, term 26] append failure for follower {raft_identity,raft_server_ha_raft_1,'ncsd@nso02.example.com'}. Follower reports local log ends at 0. <INFO> 10-Jul-2023::10:31:45.442 9ccc7c1bdb1d ncs[152]: Leader[raft_server_ha_raft_1, term 26] append failure for follower {raft_identity,raft_server_ha_raft_1,'ncsd@nso03.example.com'}. Follower reports local log ends at 0.
NSO01 leader node:
    <ha-raft>
    <enabled>true</enabled>
    <cluster-name>amsterdam</cluster-name>
    <listen>
      <node-address>nso01.example.com</node-address>
    </listen>
    <seed-nodes>
      <seed-node>nso02.example.com</seed-node>
    </seed-nodes>
    <ssl>
      <ca-cert-file>${NCS_CONFIG_DIR}/ssl/cert/ca.crt</ca-cert-file>
      <cert-file>${NCS_CONFIG_DIR}/ssl/cert/nso01.crt</cert-file>
      <key-file>${NCS_CONFIG_DIR}/ssl/cert/nso01.key</key-file>
    </ssl>
  </ha-raft>
 NSO02 seed node:
<ha-raft>
    <listen>
      <node-address>nso02.example.com</node-address>
    </listen>
    <seed-nodes>
    </seed-nodes>
    <ssl>
      <cert-file>${NCS_CONFIG_DIR}/ssl/cert/nso02.crt</cert-file>
      <key-file>${NCS_CONFIG_DIR}/ssl/cert/nso02.key</key-file>
    </ssl>
  </ha-raft>
NOS03:
<ha-raft>
    <listen>
      <node-address>nso03.example.com</node-address>
    </listen>
    <seed-nodes>
    </seed-nodes>
    <ssl>
      <cert-file>${NCS_CONFIG_DIR}/ssl/cert/nso03.crt</cert-file>
      <key-file>${NCS_CONFIG_DIR}/ssl/cert/nso03.key</key-file>
    </ssl>
  </ha-raft>
Hi Erdem,
The problem is been solved with Cisco TAC.
we simply deleted the snapshot:   rm -rf /nso/run/state/raft/ha_raft.1/snapshot.0.0
and now it works again.
eaksu
Hello BasharAziz,
Thanks for sharing. The 'ncsd@' part is implicitly added as it forms the internal representation for node names together with hostname.
Create cluster issue needs to be investigated further. Could you share the raft.log and devel.log?
From what you shared, it looks like the cluster was formed but later 'nso02.example.com' got stalled for some reason.
Erdem
Hi Erdem,
I am glad that your issue was resolved.
Cheers!
