NSO Installation requirements
RichardD2
Does anyone have hardware/vm specs for installing NSO on laptop for development. I.e. not in production.
thanks
vleijon
There are no formal requirements, but here are some advise that has worked well for me.
It runs on pretty much any modern Mac or Linux laptop, just make sure you have at least 8 GB of memory. More memory allows you to run larger netsim environments so 16GB is a plus - especially if you run eclipse or intellij for your development. If you run Windows and want to run a linux VM I'd recommend 16GB.
The CPU doesn't matter much until you start scaling, anything except the very most low-end should work, only x86-64 though.
vleijon
