NSO NED: java class file has not been foud
Hi guys
i get this error when use the command package reload
Error: The following Java classes look suspicious:
cisco-ise: .class file for com/tailf/packages/ned/cisco/ise/CiscoISENedGeneric.java has not been found
cisco-ise: .class file for com/tailf/packages/ned/cisco/ise/CiscoISEJsonTransformer.java has not been found
cisco-ise: .class file for com/tailf/packages/ned/cisco/ise/CiscoISEDp.java has not been found
cisco-ise: .class file for com/tailf/packages/ned/cisco/ise/CiscoISEConnection.java has not been found
cisco-ise: com.tailf.packages.ned.cisco.ise.CiscoISENedGeneric is declared in package-meta-data.xml but not found
cisco-ise: com.tailf.packages.ned.cisco.ise.CiscoISEDp is declared in package-meta-data.xml but not found
Check that the corresponding packages have been properly compiled.
If this is intended, proceed with 'force' parameter.
But these files exist
root@kevin-virtual-machine:~/ncs-run/packages/cisco-ise/src/java/src/com/tailf/packages/ned/cisco/ise# ls
CiscoISEConnection.java  CiscoISEDp.java  CiscoISEJsonTransformer.java  CiscoISENedGeneric.java
i dont know what is the problem.
thanks for your help
best regards
perander
Are the files compiled correctly as the error message suggests?
What's missing seems to be the .class files, not the .java files.
billirubin05120
I am having the same problem. I received this problem when trying to do the packages-reload command on the resource-manager package in the NSO and it showed that .class files are missing for the following files: ResourceException.java , ResourceAllocator.java , ResourceErrorException.java and ResourceWaitException.java. There is another file over here in this package, it is called ErrorCode.java, however I had no problems compiling this file and receiving the .class file for it. It appears to me that the java code for the error-ed files is correct and all of the files are within the same package, so I believe that using variables from one class in another class should be done without a problem.
Could someone explain to me why I am receiving this problem and how I can fix it? Below I have attached pictures of the errors I am receiving for the files mentioned above.
PS: The ResourceAllocator.java file showed 100 errors, so in the picture I have provided only a part of them - all of the errors below the ones in the picture are related to the missing packages (which I don't know where to find and how to implement).
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
