NSO not able to find netsim created devices
jaswant6068
I have devices created using netsim ios0 and ios1 successfully and was able to start them.
However when I tried to sync from these devices, it seems like ncs is not able to find the devices.
gag@Jas:~/ncs-run$ ncs-netsim start
DEVICE ios0 OK STARTED
DEVICE ios1 OK STARTED
gag@Jas:~/ncs-run$ ncs_cli -u admin -C
admin connected from 127.0.0.1 using console on Jaswant-Singh
admin@ncs# show devices
ID NAME REVISION NAMESPACE
lsa-netconf
netconf
snmp
cisco-ios-cli-3.0 tailf-ned-cisco-ios 2014-02-12 urn:ios
tailf-ned-cisco-ios-stats - urn:ios-stats
admin@ncs# devices sync-from
admin@ncs# devices device ios0 check-sync
syntax error: element does not exist
admin@ncs#
Getting error when I tried to check sync status for the devices.
9 Replies 9
vleijon
You have to explicitly add the devices to nso. There are a few ways of doing this, if you create your netsims before running ncs-setup you can use the --netsim-dir option to ncs-setup, or you can use ncs-netsim ncs-xml-init > init.xml and then load merge init.xml in ncs_cli (which is what I usually do).
nisheeth
I had created the 4 devices using the netsim
ncs-netsim create-network ./packages/neds/cisco-nx-cli-3.0 3 device --dir ./netsim
ncs-netsim add-to-network ./packages/neds/cisco-ios-cli-3.0 1 device --dir ./netsim
Cannot view any devices from the webui and read your note and followed the steps below
I exported the netsim using the command ncs-netsim ncs-xml-init > netsim.xml
Then tried to load the same file using ncs_load with -m option and that failed at the ned id
ubuntu@nsovm:~/ncs-6.1$ ncs_load -lm netsim.xml
ncs_load: 645: maapi_load_config(sock, tid, flags, abspath(argv[0])) failed: external error (19): Error on line 26: invalid value for: ned-id in /ncs:devices/ncs:device[ncs:name='device0']/ncs:device-type/ncs:cli/ncs:ned-id: "id:cisco-nx-cli-3.0" is not a valid value.
The issue is NSO does not have these NEDs loaded.
You need to take the NEDs from packages/neds and copy them into the packages directory where you started your NSO. Then do a package reload to ensure the NEDs are running in your NSO instance.
I see though, you are using the NEDs that are delivered with the NSO installation. Beware these are actually not the official NEDs but are shrunk down versions that are delivered to run with the examples that are shipped with NSO.
Also I see you I see this
which means your current directory is the same directory as where you installed NSO. It is generally bad proactice to make changes inside the NSO installation, I would go to a separate directory and do ncs-setup there and put the netsin directory there as well.
I have followed the steps, this is what I used
I am using netsim to create the devices
The path for neds are ./packages/neds/cisco-ios-cli-3.0 1 so the netsim has build them correctly and the netsim shows that.
The issue is I don't see neds either in ncs_cli or webui . I see the default packages and not the cisco neds due to that due to that I don't see the devices in webui as what is shown by netsim
Using ncs_cli -C -u admin I cannot update the configuration like
ubuntu@nsovm:~/ncs-6.1$ ncs-netsim create-network ./packages/neds/cisco-ios-cli-3.0 1 device --dir ./netsim
ubuntu@nsovm:~/ncs-6.1$ ncs-netsim add-to-network ./packages/neds/cisco-ios-cli-3.0 1 device --dir ./netsim
ubuntu@nsovm:~/ncs-6.1$ ncs-netsim list
ncs-netsim list for /home/ubuntu/ncs-6.1/netsim
name=device0 netconf=12022 snmp=11022 ipc=5010 cli=10022 dir=/home/ubuntu/ncs-6.1/netsim/device/device0
name=device1 netconf=12023 snmp=11023 ipc=5011 cli=10023 dir=/home/ubuntu/ncs-6.1/netsim/device/device1
name=device2 netconf=12024 snmp=11024 ipc=5012 cli=10024 dir=/home/ubuntu/ncs-6.1/netsim/device/device2
name=device3 netconf=12025 snmp=11025 ipc=5013 cli=10025 dir=/home/ubuntu/ncs-6.1/netsim/device/device3
ubuntu@nsovm:~/ncs-6.1$ ncs-netsim packages
/home/ubuntu/ncs-6.1/packages/neds/cisco-nx-cli-3.0
/home/ubuntu/ncs-6.1/packages/neds/cisco-ios-cli-3.0
admin@ncs# show devices ned-ids
lsa-netconf
netconf
snmp
I cannot update ios because it shows only three types of ned as mentioned above and because it doesn't have ned-id ios
admin@ncs#
admin@ncs# config
devices device device0
address 127.0.0.1 port 10025
device-type cli ned-id cisco-ios protocol ssh
authgroup default
state admin-state unlocked
commit
ssh fetch-host-keys
sync-from
end
do Thanks
Nisheeth
huayyang
Please check the document how to add a NED package https://developer.cisco.com/docs/nso-guides-6.1/#!administration/packages
nisheeth
I followed all the steps as mentioned and what i realize that the nso reads the packages from ~/$NCS_DIR/etc/ncs/nso.conf
As per the ncs.conf it reads the packages described in ~/$NCS_DIR/etc/ncs/ and it has the directory snmp, ssh and ssl
The snmp has fxs files whcih cdb understand.
So i want to know how ic an create the same information for ios, nx and iosxr
I have compiled the packages too and  the neds-id are not getting it is not getting updated in the ~/$NSC_DR/ncs and ncs.conf therefore it doesnt show up in ncs_cli
lsa-netconf
netconf
snmp
admin@ncs#
need to know what are the additional steps to be done
huayyang
NCS_DIR is the installation directory, you can create a "packages" directory in $NCS_DIR/etc/ncs and put your NEDs there, but you probably want to put your NEDs in the packages directory under "run directory"($NCS_RUN_DIR/packages, which is /var/opt/ncs/packages by default), so you don't need to copy the packages between different NSO installations.
Jesus Illescas
If you are starting with NSO and netsim, take a look at this Interactive Learning Lab that uses NSO in local install mode, where using netsim and ncs-setup we created an environment to experiment with NSO. You can play directly with the container to see what the environment variables are set to.
https://developer.cisco.com/learning/labs/learn-nso-with-netsim/introduction/
