NSO script command and PIP
romain.guilloux
Frequent Visitor
Frequent Visitor
I've made a python package that I have install using pip, in NSO I have created a cli command that uses my python package but it failed : I want to know which python and pip NSO uses ? and how to create a script command using external python package in NSO ?
In bin/ncs-start-python I have set python3.4 to be used by NSO.
In a shell, when I perform pip3.4 freeze I have :
my-package==0.0.1
I have made a test to print it in NSO which showed this :
in test.sh  :
set -e
while [ $# -gt 0 ]; do
    case "$1" in
        --command)
            cat << EOF
begin command
    modes: oper
    styles: c i j
    cmdpath: echo-totot
    help: echo toto
end
EOF
            exit
            break
    esac
    shift
done
echo `which python3.4`
echo `which pip3.4`
echo `pip3.4 freeze`
I performed a package reload, a script reload and launched my command :
rguilloux@ncs# echo-totot
/usr/bin/python3.4
/usr/bin/pip3.4
So :
1- global python3.4 is used
2- global pip3.4 is used
3- It doesn't show any python package
How to use a pip package in NSO script command ?
Any help please ?
Romain
mvolf
For running and testing ncs/python code/... in different Python environments I use virtualenv - I create a new or use existing virtual environment, switch to it and start NSO there, NSO and anything started from NSO happily picks whatever the environment provides. Looks to me this would work for you as well.
mvolf
