NSO service not applied on netsim device
RobinKhn
Hi everyone, I have the following problem:
I created a simple loopback-service to get myself familiar with NSO. I created the necessary YANG and XML files (see below). I compiled the YANG file, and reloaded the packages in the NSO CLI, so there shouldn't be a problem on that side. My device is a simple ios device which I created with netsim. However when I apply my loopback-service to that device and then do a "commit dry-run outformat native", the result is empty, which means the configuration is not going to be applied correctly. After commiting, I can't see the configured Loopback in the running-config of the device.
Here the YANG file:
module loopback-service {
  namespace "http://com/example/loopbackservice";
  prefix loopback-service;
  import ietf-inet-types {
    prefix inet;
  import tailf-ncs {
    prefix ncs;
  list loopback-service {
    key device;
    uses ncs:service-data;
    ncs:servicepoint "loopback-service";
    leaf device {
      type leafref {
        path "/ncs:devices/ncs:device/ncs:name";
    list Loopbacks {
      key loid;
      leaf loid {
        type uint32;
        description "Loopback Interface number";
      leaf vrfname {
        type string;
        description "VRF Name";
      leaf ipadd {
        type inet:ipv4-address;
        description "IP-Address";
        mandatory true;
And here the XML file:
<config-template xmlns="http://tail-f.com/ns/config/1.0"
                 servicepoint="loopback-service">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device>
          Select the devices from some data structure in the service
          model. In this skeleton the devices are specified in a leaf-list.
          Select all devices in that leaf-list:
      <name>{/device}</name>
      <config>
      <interface xmlns="urn:ios">
                     <Loopback>
                       <name>{/loid}</name>
                       <ip-vrf>
                         <ip>
                           <vrf>
                             <forwarding>{/vrfname}</forwarding>
                           </vrf>
                         </ip>
                       </ip-vrf>
                       <ip>
                         <address>
                           <primary>
                             <address>{/ipadd}</address>
                             <mask>255.255.255.255</mask>
                           </primary>
                         </address>
                       </ip>
                     </Loopback>
                   </interface>
            </config>
    </device>
  </devices>
</config-template>
I apply the service to my device (called c0) with the following command:
loopback-service c0 Loopbacks 123 ipadd 1.2.3.4 vrfname v-private
And the resulting dry-run outformat native is empty; the xml outformat looks like this:
result-xml {
    local-node {
        data <loopback-service xmlns="http://com/example/loopbackservice">
               <device>c0</device>
               <Loopbacks>
                 <loid>123</loid>
                 <vrfname>v-private</vrfname>
                 <ipadd>1.2.3.4</ipadd>
               </Loopbacks>
             </loopback-service>
What am I missing? Why is the service not applied to my device?
Any help would be greatly appreciated, thanks in advance,
Robin
Found already a solution, the problem was in my xml-file. The variables "loid", "ipadd" and "vrfname" are inside the list "Loopbacks" (see yang file), and when I want to reference those leafs in the xml file, I need to specify that list as well. For example, in the xml file I need to reference the leaf "loid" with /Loopbacks/loid and not only with /loid.
vleijon
I think you are missing to set a device in your loopback-service, you need to say which devices you want it applied ot.
