NSO services that does not save
Hi all,
i'm trying to create a service in python that when called kick off a bunch of cli commands (not config) eg show run
then outputs are saved in files not the cdb.
i don't what to create a service instance each time i call the services only to have to delete it
eg don't even want to give it a name
what do ppl suggest
Yale
PS must be do with Python not java
To answer your question, I also created this blog at my previous job for NSO actions basics:
https://www.networktocode.com/blog/post/NSO-tips-and-tricks/
vleijon
It sounds like an action to me, so I would suggest looking into that.
could you pls point me in the direction of the documentation
Yale
I would start with examples.ncs/getting-started/developing-with-ncs/2-actions-py but this is also covered in the development guide (under Python VM there is a sub-sub chatper called “Action Requests”).
