Couldn't able to create devices.xml file using ncs_load -l -m devices.xml Error at ncs_load: 618: maapi_load_config
kiran kotari
[nsoadmin@etc-emix-nso ncs]$ ncs_load -l -m devices.xml
ncs_load: 618: maapi_load_config(sock, tid, flags, abspath(argv[0])) failed: system call failed (24): couldn't open file /var/opt/ncs/devices.xml: no such file or directory
I created the file manually using `touch devices.xml` then I got the following error:
ncs_load: 618: maapi_load_config(sock, tid, flags, abspath(argv[0])) failed: external error (19): Error on line 1: End-of-file reached in XML stream
yfherzog
Are you trying to load netsim devices into NSO or something like that?
If so, before you try to use the file, it needs to be generated with: ncs-netsim ncs-xml-init > devices.xml
Refer to the procedure on the user guide under "Using Netsim".
yfherzog
Oops, I forgot that.
