NSO sync-from Junos SSH subset not supported
RobvdL
I've loaded a netsim with Junos, IOS-XE,NX and Fortios and I've added the devices in NSO v4.7
Also I've loaded the nso4.7 most recent neds.
I fetched the keys without any problem.
But now when I want to sync-from to all devices, only the Junos devices are reporting an error.
sync-result {
device xxxx
result false
info Failed to authenticate towards device xxxx: SSH subsystem not supported
I've added the Junos devices like this
devices device xxx
address 127.0.0.1 port 10023
device-type netconf ned-id netconf
authgroup lab-test
state admin-state unlocked
The auth group is:
devices authgroups group lab-test
default-map remote-name admin
default-map remote-password admin
Now when I change the password I receive the following error:
root@ncs(config)# devices device xxx sync-from
result false
info Failed to authenticate towards device xxx: Bad password for local/remote user admin/test
Also when I change the authgroup to use root/root I get the same errors. (First I needed to set the root password in the netsim.)
What do I do wrong?
lmanor
I noticed that your port configured on you on-boarded Juniper device is 10023..
Did you explicitly create your netsim device using this port?
Generally, by default the netsim devices are created using 12022, and increment for successive devices...
admin@ncs% show devices device * port
device jnpr-0 {
port 12022;
device jnpr-1 {
port 12023;
lmanor
device jnpr-0 {
port 12022;
device jnpr-1 {
port 12023;
Yes you're right, thanks! I have now a successfully added all devices.
Didn't realize it with all those other cli based NEDs.
ncs-netsim list
name=xxx netconf=12022 snmp=11022 ipc=5010 cli=10022 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12023 snmp=11023 ipc=5011 cli=10023 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12024 snmp=11024 ipc=5012 cli=10024 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12025 snmp=11025 ipc=5013 cli=10025 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12026 snmp=11026 ipc=5014 cli=10026 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12027 snmp=11027 ipc=5015 cli=10027 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12028 snmp=11028 ipc=5016 cli=10028 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12029 snmp=11029 ipc=5017 cli=10029 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12030 snmp=11030 ipc=5018 cli=10030 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12031 snmp=11031 ipc=5019 cli=10031 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12032 snmp=11032 ipc=5020 cli=10032 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12033 snmp=11033 ipc=5021 cli=10033 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12034 snmp=11034 ipc=5022 cli=10034 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12035 snmp=11035 ipc=5023 cli=10035 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12036 snmp=11036 ipc=5024 cli=10036 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12037 snmp=11037 ipc=5025 cli=10037 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12038 snmp=11038 ipc=5026 cli=10038 dir=/root/install/lab/netsim/xxxx/xxxx
name=xxx netconf=12039 snmp=11039 ipc=5027 cli=10039 dir=/root/install/lab/netsim/xxxx/xxxx
At least now I'll never forget it :)
lmanor
A quick related tip here... which is quite useful when using many netsim devices
For the netsim devices that you create you can use the ncs-setup tool to create the device on-boarding configuration automatically to a file which can be loaded by NSO on its initial startup or 'load merged' into the CDB at a later time.
Example:
$ ncs-netsim create-network ./packages/cisco-iosxr 2 asr
DEVICE asr0 CREATED
DEVICE asr1 CREATED
$ ncs-netsim add-to-network ./packages/juniper-junos 2 mx
DEVICE mx0 CREATED
DEVICE mx1 CREATED
$ ncs-netsim start
DEVICE asr0 OK STARTED
DEVICE asr1 OK STARTED
DEVICE mx0 OK STARTED
DEVICE mx1 OK STARTED
## Add netsim devices to NCS startup config in ncs-cdb/netsim_devices_init.xml
$ ncs-setup --netsim-dir ./netsim --dest .
$ ls ncs-cdb
This xml file will be read at NSO initialization when it is first started to provide the initial on-boarding config for the netsim devices.
Or, if NSO had previously been run prior to netsim network creation, simply 'load merge' the netsim_devices_init.xml file from NSO cli config mode to pull in the initial netsim device initial configurations:
% load merge ncs-cdb/netsim_devices_init.xml
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
