NSO sync-from vs Pioneer get-config (Nokia netconf problem)
Iman1
Built the netconf NED for latest SROS 15.0R4 using yang models provided by Nokia. Attempting to sync-from the device gives an error, but using Pioneer get-config works. I investigated the raw netconf traces, and the issue seems to be due to following:
Pioneer get-config sends the following message without using any filter, and device returns configs properly.
<?xml version="1.0" encoding="UTF-8"?>
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
    <get-config><source><running/></source></get-config>
</rpc>
...but sync-from command sends the following message to which Nokia router returns an error.
<get-config><source><running/></source><filter><configure xmlns="urn:alcatel-lucent.com:sros:ns:yang:conf-r13"></configure></filter></get-config></rpc>
Nokia device returns:
<rpc-reply message-id="1" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
    <rpc-error>
        <error-type>application</error-type>
        <error-tag>operation-failed</error-tag>
        <error-severity>error</error-severity>
        <error-info>
            <err-element>get-config</err-element>
        </error-info>
        <error-message>
            command failed - &apos;configure&apos;
            MINOR: CLI Command not allowed for this user.
        </error-message>
    </rpc-error>
</rpc-reply>
Is this because of errors in Nokia yang? but what makes NSO to pick that yang model as a "filter" for its get-config request?
Jan Lindblad
Not necessarily in the YANG. I'd say there is a problem in their NETCONF implementation.
If you have relevant contacts at Nokia/ALU, I'd be happy get into the conversation.
Jan Lindblad
