NSO to search for individual fiels or literals
WilliamEccles33
I am very new to NSO....
Is there a way using NSO to search configs, both running and offline, using a literal/regx to find if something is administered or in a configuration on one or many devices?
Possibly a way to search the CDB?
OR create a search on each device?
vleijon
I am not entirely sure what you want to achieve here, and it’d be good if you give an example.
You can in general search in the database using xpath queries, that might be enough for your use-case.
