NSO XML Template Problem
casbarre
Hello everyone!
After upgrading NSO 4.7 to NSO 5.7, I tried to add previous Services to the new NSO version but when I perform a packages reload, a XML template error is displayed: "The node: [node-name] contains unxpected data".
These are the services I'm trying to add to NSO:
packages package l3vpn
 oper-status file-load-error
 oper-status error-info [ "vrp-route-policy.xml:83 The node: as-path-filter contains unexpected data: '{as-path-match-name}'." "l3vpn-vrp-template.xml:403 The node: load-balancing contains unexpected data: '{routing-protocol/vr...'." ]
packages package rsvp-te-tunnel
 oper-status error-info [ "rsvp-te-tunnel-template.xml:170 The node: destination contains unexpected data: '{$TAILEND_LOOPBACK_I...'." ]
For example, L3VPN's vrp-route-policy.xml line 83 looks like this:
<as-path-filter when="{type='as-path'}">{as-path-match-name}</as-path-filter>
RPSV-TE-TUNNEL's rsvp-te-tunnel-template.xml line 170 looks like this:
 <destination>{$TAILEND_LOOPBACK_IP}</destination>
I'm not sure if there is something wrong with the templates or the YANG models. What should I check to fix this problem?
Thank you in advance!
Since your problem is concerning  only the huawei-vrp. I  will focus only on your problem using Huawei vrp 6.22.4 . I faced the  same issue.
I think you are facing this problem because you upgrade to a newer version of the NED even if it's not the last one and the yang model of the configuration that you are trying to push changed . You  will have to change your template in order to fix your problem.  You should keep in mind it's better to use the latest version
Please test again your package against REAL Device .
So to solve i started by creating  NETSIM in order to generate the new XML template
nabil@DESKTOP-8ECTID4:~/ncs-run-5.7.2.1$ ncs-netsim create-network packages/huawei-vrp-cli-6.22/  1 NETSIM-VRP-
DEVICE NETSIM-VRP-0 CREATED
nabil@DESKTOP-8ECTID4:~/ncs-run-5.7.2.1$ ncs-netsim start
17 bytes parsed in 0.29 sec (57 bytes/sec)
DEVICE NETSIM-VRP-0 OK STARTED
nabil@DESKTOP-8ECTID4:~/ncs-run-5.7.2.1$ ncs-netsim ncs-xml-init  NETSIM-VRP-0
<devices xmlns="http://tail-f.com/ns/ncs">
<device>
<name>NETSIM-VRP-0</name>
<address>127.0.0.1</address>
<port>10022</port>
<ssh>
<host-key>
<algorithm>ssh-ed25519</algorithm>
<key-data>ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIPbbKtetr97CPxfitcIzhYXJxWS4HSuZ7NBTmgU6Lw4C nabil@DESKTOP-8ECTID4</key-data>
</host-key>
<host-key>
<algorithm>ssh-rsa</algorithm>
<key-data>ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABgQDKgyIpx0AlNwEzs7zGgnkEDut5E7ztNgo5FMqJ5v8Pp5+nIgkwrbvL7mAwl9kybU69pJvM3vAbzruVDvmYA6jJwvtbWzWMoGkna
hQQsTVRaCCpVBOYQzFckrhLBy4O1y8GZwR1jadwNDMkaqoEssF9Yjfy+eTuqff6N0WxTbbPEOPWJ8y5LM5iHKUF9gp3bcRta+iRpxwrDEcUfJOpsCKXOXiXU7DKsJjn/WlVLoSOCrEW2gRMqkgmqr8HW7pDQ
hfzQcr7qeFbYUi3wPSd1Zb9gXDq2x514gvWkJesXlskGvPoTemGcPWdy0z7KH7v7iOGKqBJGSaiPlucQL4QOZfUjy6xnjt0KHCFJ0/y1I2LXoO6RSyoFk7XZ5NphgB2lWMHm5VtdYzJyqcyWBU4tOqEOfBsd
0ro48c2lXTU2sZ8D+jxjUsxhrax/Zo9D9lmgegItKBm9Ja5NIBbfumf1x61sbcoXyahbP5B00oURo1WVDR7N9qHHeDJ4GS8aTzxLpM= nabil@DESKTOP-8ECTID4</key-data>
</host-key>
</ssh>
<ssh-algorithms>
<public-key>ssh-ed25519</public-key>
<public-key>ssh-rsa</public-key>
</ssh-algorithms>
<state>
<admin-state>unlocked</admin-state>
</state>
<authgroup>default</authgroup>
<device-type>
<cli>
<ned-id xmlns:id="http://tail-f.com/ns/ned-id/huawei-vrp-cli-6.22">id:huawei-vrp-cli-6.22</ned-id>
</cli>
</device-type>
</device>
</devices>
Then i load the NETSIM in NSO and try to configure the NETSIM in order to get the XML config.
admin@ncs(config)# show configuration
devices device NETSIM-VRP-0
 config
  interface Tunnel0/0/3
   destination 1.1.1.1
   no shutdown
  exit
admin@ncs(config)# commit dry-run outformat xml
result-xml {
    local-node {
        data <devices xmlns="http://tail-f.com/ns/ncs">
               <device>
                 <config>
                   <interface xmlns="http://tail-f.com/ned/huawei-vrp">
                     <Tunnel>
                       <name>0/0/3</name>
                       <destination>
                         <address>1.1.1.1</address>
                       </destination>
                     </Tunnel>
                   </interface>
                 </config>
               </device>
             </devices>
The route-policy part :
 config
  route-policy TEST node 1
   if-match as-path-filter AAA
result-xml {
    local-node {
               <device>
                 <config>
                   <route-policy xmlns="http://tail-f.com/ned/huawei-vrp">
                     <name>TEST</name>
                     <node>1</node>
                     <if-match>
                       <as-path-filter>
                         <id>AAA</id>
                       </as-path-filter>
                     </if-match>
                   </route-policy>
                 </config>
               </device>
             </devices>
The as-path part :
 config
  route-policy TEST permit node 10
   apply as-path 65000 67000 additive
result-xml {
    local-node {
               <device>
                 <config>
                     <name>TEST</name>
                     <node>10</node>
                     <rule>permit</rule>
                     <apply>
                       <as-path>65000 67000 additive</as-path>
                     </apply>
                   </route-policy>
                 </config>
               </device>
             </devices>
So i changed your template and try to reload the package.
Here the changes
nabil@DESKTOP-8ECTID4:~/ncs-run-5.7.2.1/packages/test-package/templates$ diff -U 0 test-package-template.xml.orig test-package-template.xml
--- test-package-template.xml.orig      2022-05-11 20:13:31.770874600 +0200
+++ test-package-template.xml   2022-05-11 20:35:08.890874600 +0200
@@ -39 +39,3 @@
-            <destination>{$TAILEND_LOOPBACK_IP}</destination>
+            <destination>
+       <address>{$TAILEND_LOOPBACK_IP}</address>
+          </destination>
@@ -71 +73,3 @@
-            <as-path-filter when="{type='as-path'}">{as-path-match-name}</as-path-filter>
+            <as-path-filter when="{type='as-path'}">
+          <id>{as-path-match-name}</id>
+            </as-path-filter>
@@ -81,6 +85 @@
-            <as-path when="{policy-set/as-path}">
-              <?foreach {policy-set/as-path/as-number}?>
-              <as-number>{current()}</as-number>
-             <operation>additive</operation>
-             <?end?>
-            </as-path>
+              <as-path when="{policy-set/as-path}">{concat(policy-set/as-path/as-number,'additive')}</as-path>
Here the output that i got before the modification
reload-result {
    package test-package
    result false
    info test-package-template.xml:39 The node: destination contains unexpected data: '{$TAILEND_LOOPBACK_I...'.
I got this new error-message
reload-result {
    result false
    info test-package-template.xml:87 Unknown element: 'as-number' for ned-id: huawei-vrp-cli-6.22:huawei-vrp-cli-6.22
Concering this error , i fixed the package reload message by changing your template. Since i have never used a concat on list . You should try it  and see if it's working as you expect
Then after the modification the package is up.
admin@ncs# packages reload
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has completed successfully.
reload-result {
    package huawei-vrp-cli-6.22
    result true
reload-result {
    result true
Here the XML File
<config-template xmlns="http://tail-f.com/ns/config/1.0">
    <device>
          Select the devices from some data structure in the service
          model. In this skeleton the devices are specified in a leaf-list.
          Select all devices in that leaf-list:
      <name>{/device}</name>
      <config>
            Add device-specific parameters here.
            In this skeleton the, java code sets a variable DUMMY, use it
            to set something on the device e.g.:
            <ip-address-on-device>{$DUMMY}</ip-address-on-device>
          <Tunnel>
            <name>0/0/{$TUNNEL_ID}</name>
            <description>NSO_Tactical Tunnel_to_{/tailend-router}</description>
            <ip>
              <address>
                <unnumbered>
                  <interface>
                    <LoopBack>0</LoopBack>
                  </interface>
                </unnumbered>
              </address>
            </ip>
            <isis>
              <enable>{/isis-process}</enable>
            </isis>
            <tunnel-protocol>
              <mpls>
                <te/>
              </mpls>
            </tunnel-protocol>
            <destination>
           </destination>
            <mpls>
              <te>
                <tunnel-id>{$TUNNEL_ID}</tunnel-id>
                <record-route>
                  <label/>
                </record-route>
                <path>
                  <explicit-path>NSO_TACTICAL_TE_{$TUNNEL_ID}_PRI</explicit-path>
                </path>
                <fast-reroute/>
                <igp>
                  <shortcut/>
                  <metric>
                    <absolute>{/igp-metric}</absolute>
                  </metric>
                </igp>
              </te>
            </mpls>
            <statistic>
              <enable/>
            </statistic>
          </Tunnel>
        </interface>
          <name>{$ROUTE_POLICY_NAME}</name>
          <node>{node}</node>
          <rule>{rule}</rule>
          <?foreach {policy-match}?>
          <if-match>
            <ip-prefix when="{type='prefix-match'}">{prefix-match-name}</ip-prefix>
            </as-path-filter>
            <community-filter when="{type='community-match'}">
               <name>{community-match-name}</name>
             </community-filter>
             <community-filter when="{type='community-basic-match'}">
               <name>{community-basic-match-name}</name>
             </community-filter>
            <tag when="{type='tag'}">{tag/set-name}</tag>
          </if-match>
          <apply>
            <tag>{policy-set/tag}</tag>
            <?set EXTCOMMN={none}?>
            <?set EXTCOMMNS={""}?>
            <?if {policy-set/extcommunity-rt}?>
            <?foreach {policy-set/extcommunity-rt}?>
            <?set EXTCOMMN={current()}?>
            <?set EXTCOMMNS={concat($EXTCOMMNS," rt ",$EXTCOMMN)}?>
            <?end?>
            <extcommunity>{normalize-space($EXTCOMMNS)} additive</extcommunity>
            <?end?>
            <?set COMMN={none}?>
            <?set COMMNS={""}?>
            <?if {policy-set/community}?>
            <?foreach {policy-set/community}?>
            <?set COMMN={current()}?>
            <?set COMMNS={concat($COMMNS," ",$COMMN)}?>
            <?end?>
            <?set COMMNS={normalize-space($COMMNS)}?>
            <community>{$COMMNS} additive</community>
            <?end?>
            <local-preference>{policy-set/local-preference}</local-preference>
            <cost>{policy-set/cost}</cost>
          </apply>
          <?end?>
        </route-policy>
      </config>
    </device>
  </devices>
</config-template>
Nabsch
Hello ,
Which ned are you using ? Can you provide us the name and the version ?
Could you put also the part of template that’s not working ?
Hi.
The NEDs I'm using are:
cisco-iosxr:
cisco-iosxr-cli-7.33 (Full name)
huawei-vrp:
huawei-vrp-cli-6.22 (Full name)
juniper-junos:
juniper-junos-nc-4.6 (Full name)
cisco-ios:
cisco-ios-cli-6.69 (Full name)
RSPV-TE-TUNNEL Template (the failing line is highlighted):
          <Tunnel>
            <ip>
              <address>
                <unnumbered>
                  <interface>
                  </interface>
                </unnumbered>
              </address>
            </ip>
            <isis>
            </isis>
            <tunnel-protocol>
              <mpls>
                <te/>
              </mpls>
            </tunnel-protocol>
            <mpls>
              <te>
                <record-route>
                  <label/>
                </record-route>
                <path>
                </path>
                <fast-reroute/>
                <igp>
                  <shortcut/>
                  <metric>
                  </metric>
                </igp>
              </te>
            </mpls>
            <statistic>
              <enable/>
            </statistic>
          </Tunnel>
        </interface>
L3VPN Template (the failing line is highlighted):
          <node>{node}</node>
          <rule>{rule}</rule>
          <if-match>
             </community-filter>
             </community-filter>
          </if-match>
          <apply>
             <?end?>
            </as-path>
            <?end?>
            <?end?>
            <?set COMMNS={""}?>
            <?end?>
            <?end?>
          </apply>
          <?end?>
        </route-policy>
<device>
<port>10022</port>
<ssh>
<host-key>
</host-key>
<host-key>
</host-key>
</ssh>
<ssh-algorithms>
</ssh-algorithms>
<state>
</state>
<device-type>
<cli>
</cli>
</device-type>
</device>
</devices>
 config
   destination 1.1.1.1
   no shutdown
  exit
result-xml {
    local-node {
               <device>
                 <config>
                     <Tunnel>
                       <name>0/0/3</name>
                       <destination>
                       </destination>
                     </Tunnel>
                   </interface>
                 </config>
               </device>
             </devices>
 config
result-xml {
    local-node {
               <device>
                 <config>
                     <name>TEST</name>
                     <node>1</node>
                     <if-match>
                       <as-path-filter>
                         <id>AAA</id>
                       </as-path-filter>
                     </if-match>
                   </route-policy>
                 </config>
               </device>
             </devices>
The as-path part :
 config
result-xml {
    local-node {
               <device>
                 <config>
                     <name>TEST</name>
                     <node>10</node>
                     <rule>permit</rule>
                     <apply>
                     </apply>
                   </route-policy>
                 </config>
               </device>
             </devices>
Here the changes
@@ -39 +39,3 @@
+            <destination>
+          </destination>
@@ -71 +73,3 @@
+            </as-path-filter>
@@ -81,6 +85 @@
-             <?end?>
-            </as-path>
reload-result {
    result false
reload-result {
    result false
reload-result {
    result true
reload-result {
    result true
Here the XML File
    <device>
      <config>
          <Tunnel>
            <ip>
              <address>
                <unnumbered>
                  <interface>
                  </interface>
                </unnumbered>
              </address>
            </ip>
            <isis>
            </isis>
            <tunnel-protocol>
              <mpls>
                <te/>
              </mpls>
            </tunnel-protocol>
            <destination>
           </destination>
            <mpls>
              <te>
                <record-route>
                  <label/>
                </record-route>
                <path>
                </path>
                <fast-reroute/>
                <igp>
                  <shortcut/>
                  <metric>
                  </metric>
                </igp>
              </te>
            </mpls>
            <statistic>
              <enable/>
            </statistic>
          </Tunnel>
        </interface>
          <node>{node}</node>
          <rule>{rule}</rule>
          <if-match>
            </as-path-filter>
             </community-filter>
             </community-filter>
          </if-match>
          <apply>
            <?end?>
            <?end?>
            <?set COMMNS={""}?>
            <?end?>
            <?end?>
          </apply>
          <?end?>
        </route-policy>
      </config>
    </device>
  </devices>
</config-template>
