NSO yang leafref device-group
AndyK1
Frequent Visitor
Frequent Visitor
I'm attempting to create my first service template but have issues when referencing device-groups in my yang file.
user@ncs(config)# L2-BRIDGE TEST device-group LEAF-SWITCHES vlan 10 vni 10002
user@ncs(config-L2-BRIDGE-TEST)# commit dry-run outformat native
Aborted: L2-BRIDGE-template.xml:5 The node '/ncs:devices/device{LEAF-SWITCHES}' was not created. An explicit tag 'merge' or 'create' is needed.
The device-group LEAF-SWITCHES exists within NSO and contains some switches.
    leaf-list device-group {
      type leafref {
        path "/ncs:devices/ncs:device-group/ncs:name";
If I replace 'device-group' with 'device' I am able to run the service against individual nodes.
Any pointers would be appreciated.
Hmm.. Stupid thing ate my xml tags..
Trying again:
Ok, the problem is here:
  <devices xmlns="http://tail-f.com/ns/ncs">
  <device>
    <name>{/device-group}</name>
If you do "commit dry-run | debug template", you can see that the expression {/device-group} evaluates to the single device-group name, and that is given as the name of the device to the template above. What you need is to get the devices inside that device-group.
In this case, you can use 'deref' to dereference the leafref in your service model. So, you can use something like
  <device>
    <name>{deref(/device-group)/../member}</name>
(/devices/device-group/member is the flattened list of all members of a device-group. You need this, instead of devices/device-group/device-name, because device-groups can be nested).
However, the "device-group" in your service is itself a leaf-list - which means there can be multiple device-groups configured in your service model. Then the above deref won't be fully correct, since it only works for the first leaf-list entry. Now you need to iterate through the items in your service model's leaf-list, which you can do like this:
  <?foreach {/device-group}?>
  <device>
    <name>{deref(.)/../member}</name>
  </device>
  <?end?>
</devices>
Try something like this!
/Ram
5 Replies 5
ramkraja
This error message means that you should explicitly use the tag "merge" or "create" in your service template, if you want to create a new device. I'm assuming you are not creating a new device, but trying to refer to an existing device in a device-group. Could you show your yang model and the service template?
Ram
AndyK1
Frequent Visitor
Frequent Visitor
Correct, I am not trying to create a new device as they are existing within the device-group.  My goal for this initial test is to deploy the service template to all the devices within the device-group.
<config-template xmlns="http://tail-f.com/ns/config/1.0"
                 servicepoint="L2-BRIDGE">
  <device>
    <config>
      <vlan xmlns="http://tail-f.com/ned/cisco-nx">
        <vlan-list>
          <id>{/vlan}</id>
          <name>{/customer-name}</name>
          <vn-segment>{/vni}</vn-segment>
        </vlan-list>
      </vlan>
      <evpn xmlns="http://tail-f.com/ned/cisco-nx">
        <vni>
          <id>{/vni}</id>
          <l2/>
          <rd>auto</rd>
          <route-target>
            <method>import</method>
            <rt>auto</rt>
          </route-target>
          <route-target>
            <method>export</method>
            <rt>auto</rt>
          </route-target>
        </vni>
      </evpn>
      <interface xmlns="http://tail-f.com/ned/cisco-nx">
        <nve>
          <name>1</name>
          <member>
            <vni>
              <id>{/vni}</id>
              <suppress-arp/>
              <ingress-replication>
                <protocol>
                  <bgp/>
                </protocol>
              </ingress-replication>
            </vni>
          </member>
        </nve>
        <port-channel>
          <name>200</name>
          <switchport>
            <trunk>
              <allowed>
                <vlan>
                  <ids>{/vlan}</ids>
                </vlan>
              </allowed>
            </trunk>
          </switchport>
        </port-channel>
      </interface>
    </config>
  </device>
 </devices>
</config-template>
module L2-BRIDGE {
  namespace "http://com/example/L2BRIDGE";
  prefix L2-BRIDGE;
  import ietf-inet-types {
    prefix inet;
  import tailf-ncs {
    prefix ncs;
  list L2-BRIDGE {
    key customer-name;
    uses ncs:service-data;
    ncs:servicepoint "L2-BRIDGE";
    leaf customer-name {
      type string;
      type leafref {
    leaf vlan {
      mandatory true;
      type uint16;
    leaf vni {
      mandatory true;
      type uint16;
Thanks!
{/device-group}
/Ram
Trying again:
  <device>
  <device>
  <device>
  </device>
  <?end?>
</devices>
/Ram
AndyK1
Frequent Visitor
Frequent Visitor
Thanks Ram, that worked a charm!
