11-12-2017 03:15 PM - edited 03-01-2019 04:02 AM
I'm trying to build netconf NED for Nokia (ALU) device. Following the Pioneer approach I encounter an Internal compiler error (please see below). I'm going to guess it's due to problems in Nokia's yang but my question is how can I go about troubleshooting this and find which yang is problematic? There is a line below that says See log for complete details, but I couldn't locate any log related to this. Where does Pioneer store logs related to error below? Is there a way to troubleshoot further and figure out which of the Nokia's yang modules are the problem? Thanks.
admin@ncs% request pioneer yang build-netconf-ned yang-directory /win7/Nokia/15.0.R4_ALL_YANG/YANG/ ned-directory /root/ncs/4.4.2/ncs-4.4.2/packages/neds name 15r4
Cleaning up existing ned-directory
Starting build of 151 YANG modules, this may take some time
PATH=/root/ncs/4.4.2/ncs-4.4.2//bin:/root/ncs/4.4.2/ncs-4.4.2/lib/ncs/erts/bin:/root/ncs/4.4.2/ncs-4.4.2/lib/ncs/bin:/root/ncs/4.4.2/ncs-4.4.2//bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/go/bin:/root/go/bin ncs-make-package --verbose --netconf-ned /win7/Nokia/15.0.R4_ALL_YANG/YANG/ 15r4 --dest /root/ncs/4.4.2/ncs-4.4.2/packages/neds --no-java
Wrote package to /root/ncs/4.4.2/ncs-4.4.2/packages/neds
make clean fxs -C /root/ncs/4.4.2/ncs-4.4.2/packages/neds/src NCSC=/root/ncs/4.4.2/ncs-4.4.2//bin/ncsc --verbose
make: Entering directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/src'
rm -rf ncsc-out ../load-dir
cd ../netsim && make clean || true
make[1]: Entering directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/netsim'
make[1]: Leaving directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/netsim'
mkdir -p ncsc-out
mkdir -p ../load-dir
/root/ncs/4.4.2/ncs-4.4.2//bin/ncsc --verbose --ncs-compile-bundle yang \
--ncs-device-dir ncsc-out \
--ncs-device-type netconf \
cp ncsc-out/modules/fxs/*.fxs ../load-dir;
Makefile:25: recipe for target 'ncsc-out/.done' failed
make: *** [ncsc-out/.done] Error 1
make: Leaving directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/src'
Build failed. Error and warning messages below. See log for complete details
failure Build failed
[ok][2017-11-11 22:45:14]
Solved! Go to Solution.
11-14-2017 12:06 AM
As I wrote, sometimes there isn't much to go by. If you could send me the YANGs, I'd have a closer look.
11-13-2017 01:03 AM
You'll see the details if you enable the pioneer logging
admin@ncs(config)# python-vm logging level level-debug
admin@ncs(config)# commit
The log file to have a look at is logs/ncs-python-vm-pioneer.log . If the failure is not during compilation (as here), but during loading, it may also be interesting to have a look at logs/ncs.log and logs/devel.log.
There are cases where it's not so easy to figure out which YANG is causing an issue. When that happens, I sometimes try to randomly exclude half of the YANGs and see if that helps. Then successively try to narrow down where the problem is by adding and removing YANGs to the set.
If you can't figure out what the problem is, don't hesitate to reach out to me.
11-13-2017 07:06 PM
Thanks Jan. I enabled the Pioneer log as you said, but unfortunately my eyes don't see any extra information there. Nothing interesting in logs/ncs.log and logs/devel.log either. Am I missing something? Is there no further step to figure out why Pioneer complains about an internal compilation error?
==> logs/ncs-python-vm-pioneer.log <==
2017-11-13 16:56:43 - pioneer - DEBUG - ========== pioneer cb_action() ==========
2017-11-13 16:56:43 - pioneer - DEBUG - thandle=173 usid=54
2017-11-13 16:56:43 - pioneer - DEBUG - yang_build_netconf_ned() with device mr30
2017-11-13 16:56:43 - pioneer - DEBUG - Cleaning up existing ned-directory
2017-11-13 16:56:43 - pioneer - DEBUG - Starting build of 151 YANG modules, this may take some time
2017-11-13 16:56:43 - pioneer - DEBUG - run '/bin/bash /root/ncs/4.4.2/ncs-run-4.4.2/state/packages-in-use/1/pioneer/python/pioneer/ncs-make-package-verbose /win7/Nokia/15.0.R4_ALL_YANG/YANG/ 15r4 /root/ncs/4.4.2/ncs-4.4.2/packages/neds', input len=0
2017-11-13 16:56:43 - pioneer - DEBUG - run_outputfun '/bin/bash /root/ncs/4.4.2/ncs-run-4.4.2/state/packages-in-use/1/pioneer/python/pioneer/ncs-make-package-verbose /win7/Nokia/15.0.R4_ALL_YANG/YANG/ 15r4 /root/ncs/4.4.2/ncs-4.4.2/packages/neds
2017-11-13 16:56:43 - pioneer - DEBUG - run_outputfun, going in
2017-11-13 16:56:43 - pioneer - DEBUG - run_outputfun, output len=378
2017-11-13 16:56:43 - pioneer - DEBUG - PATH=/root/ncs/4.4.2/ncs-4.4.2//bin:/root/ncs/4.4.2/ncs-4.4.2/lib/ncs/erts/bin:/root/ncs/4.4.2/ncs-4.4.2/lib/ncs/bin:/root/ncs/4.4.2/ncs-4.4.2//bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/go/bin:/root/go/bin ncs-make-package --verbose --netconf-ned /win7/Nokia/15.0.R4_ALL_YANG/YANG/ 15r4 --dest /root/ncs/4.4.2/ncs-4.4.2/packages/neds --no-java
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=57
2017-11-13 16:56:44 - pioneer - DEBUG - Wrote package to /root/ncs/4.4.2/ncs-4.4.2/packages/neds
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=113
2017-11-13 16:56:44 - pioneer - DEBUG - make clean fxs -C /root/ncs/4.4.2/ncs-4.4.2/packages/neds/src NCSC=/root/ncs/4.4.2/ncs-4.4.2//bin/ncsc --verbose
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=71
2017-11-13 16:56:44 - pioneer - DEBUG - make: Entering directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/src'
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=28
2017-11-13 16:56:44 - pioneer - DEBUG - rm -rf ncsc-out ../load-dir
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=35
2017-11-13 16:56:44 - pioneer - DEBUG - cd ../netsim && make clean || true
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=77
2017-11-13 16:56:44 - pioneer - DEBUG - make[1]: Entering directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/netsim'
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=76
2017-11-13 16:56:44 - pioneer - DEBUG - make[1]: Leaving directory '/root/ncs/4.4.2/ncs-4.4.2/packages/neds/netsim'
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=18
2017-11-13 16:56:44 - pioneer - DEBUG - mkdir -p ncsc-out
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=21
2017-11-13 16:56:44 - pioneer - DEBUG - mkdir -p ../load-dir
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=299
2017-11-13 16:56:44 - pioneer - DEBUG - /root/ncs/4.4.2/ncs-4.4.2//bin/ncsc --verbose --ncs-compile-bundle yang \
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=24
2017-11-13 16:56:44 - pioneer - DEBUG - Internal compiler error
2017-11-13 16:56:44 - pioneer - DEBUG - run_outputfun, output len=160
2017-11-13 16:56:44 - pioneer - DEBUG - Makefile:25: recipe for target 'ncsc-out/.done' failed
2017-11-13 16:56:44 - pioneer - DEBUG - run_finished, output len=1357
2017-11-13 16:56:44 - pioneer - DEBUG - Output from build
mkdir -p ncsc-out
2017-11-13 16:56:44 - pioneer - DEBUG - Build failed. Error and warning messages below. See log for complete details
11-14-2017 12:06 AM
11-13-2017 01:45 AM
Iman,
In our previous tests against Nokia NETCONF inteface, they are having a basic non-compliance with the standard that is preventing them to work with NSO and other systems. Basically, Nokia allows a single lock and not one per datastore. They promised to solve this issue (I believe maybe later this year) but just be sure that you are testing their latest release in case they did.
Please see some ODL mailing list discussions: https://lists.opendaylight.org/pipermail/netconf-dev/2016-August/000560.html
Roque
11-13-2017 07:24 PM
Thanks Roque.
Yes, I'm aware of that particular issue with Nokia's netconf implementation. The way I have worked around that issue is by disabling running DS capability on Nokia device, and that way NSO only tries to hold a lock on candidate DS. I think we'll have to wait for SROS 16 at minimum for a permanent fix to this issue.
The problem I have in this thread though seems to be YANG related, and I'm wondering how to go about troubleshooting it.
Iman
12-21-2017 03:26 PM
01-02-2018 01:34 AM
I had a look and found the reason for the internal compiler error: a couple of modules imported themselves(!). Once that was fixed, there were other errors cropping up. All in all I fixed two dozen issues, look for JLINDBLA in the YANGs if you want to see what I did. 60 of the modules in the package have zero size; I guess the download failed somehow. After removing them and with the fixes above, the module set compiles and loads on NSO 4.5.1.
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
