Possible To Hide NSO Packages In GUI
RyanWayno20056
Hi All,
We have a NSO deployment using the stacked services model. As such we have a "Main" module and then multiple "Child" modules that actually build individual services:
Module_Main
  Module_Child
  Module_Child
  Module_Child
Currently when we make the modules and do a packages reload, all modules show up in the drop down in the NSO GUI. I would like to only display the Module_Main in the drop-down instead of all the child modules too. Is there some method to do this (hide the module, but still have it be functional as normal) like a flag or something I can set?
Thanks in advance for your help!
joborglu
I am not sure which dropdown you are referring to. But in general, if you want to hide data you can use the yang attribute tailf:hidden a.k.a. hidden data and hidegroups.  The "hidden" statements is an extension defined in the tail-common YANG module.
e.g in the yang use:
tailf:hidden hiddenthings;
A hide group can only be unhidden if the group is listed in the ncs.conf
<hide-group>
<name>hiddenthings</name>
</hide-group>
Then you can unhide the data in the current session, e.g. cli:
unhide hiddenthings
The data should be hidden in the webui, but currently there is no option to unhide it. The jsonrpc the method is called unhide_schema. If needed you can use curl to manually call unhide_schema in the current transaction.
/Jon
joborglu
<hide-group>
</hide-group>
unhide hiddenthings
/Jon
Hi Jon,
Thanks very much for the reply, that does exactly what I needed and the package is no longer visible in the GUI after the change but still functions properly. To further elaborate for anyone else who may need the same thing, I implemented it like this:
list MY_LIST {
description "List that builds stuff.";
tailf:hidden no_gui;
key my_key;
leaf my_leaf {
  description "This is a leaf.";
  type string;
Inserting it where I did will hide the entire list, but you could probably hide smaller parts of the code with it if you needed to.
Thanks again for the help!
