Device is locked in a check-sync operation by session 23327
amitsin8
Today i am facing issue , device is locked in check-sync operation
i have checked there is no session enable with 23327 session id on NSO but it is still showing
After restart ncs it is working fine
Can some one please check and help to fix the issue
As per below link this bug has fixed in NSO version 4.7.4 but i am facing issue with same version
https://community.cisco.com/t5/nso-developer-hub-discussions/device-is-locked-in-a-sync-from-operation-by-session/td-p/3849175
My NSO log is below
[root@12 ncs]# ncs --version
4.7.4
root@ncs# devices device API check-sync
result error
info API: Device is locked in a check-sync operation by session 23327
root@ncs#
0 Replies 0
