Problem Facing to set as-number in vpn l3vpn (for example vpn l3vpn volvo) in Managing Network Services Chapter 5 - Running an example
samya.ghosh
Dear All,
I am trying to run an example in Managing Network Services Chapter 5 - NSO_getting_Started.
The example running well until vpn l3vpn configuration with as-number 65101.
i am using Ubuntu - Unix .
here is my command line scenario....
admin@ncs# devices sync-from
sync-result {
    device ce0
    result true
sync-result {
    device ce1
    result true
sync-result {
    device ce2
    result true
sync-result {
    device ce3
    result true
sync-result {
    device ce4
    result true
sync-result {
    device ce5
    result true
sync-result {
    device ce6
    result true
sync-result {
    device ce7
    result true
sync-result {
    device ce8
    result true
sync-result {
    device p0
    result true
sync-result {
    device p1
    result true
sync-result {
    device p2
    result true
sync-result {
    device p3
    result true
sync-result {
    device pe0
    result true
sync-result {
    device pe1
    result true
sync-result {
    device pe2
    result true
sync-result {
    device pe3
    result true
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# vpn l3vpn volvo
admin@ncs(config-l3vpn-volvo)# as-number 65101
syntax error: unknown command
Always facing this problem with that as-number command & when I configure the l3vpn without as-number or set as-number inside config-endpoint-main-­office I get error during commit dry-run outformat native.
Here is my scenario ...
admin@ncs(config)# commit dry-run outformat native
Aborted: 'vpn l3vpn volvo route-distinguisher' is not configured
Here is the command documentation from cisco getting stated....
ncs# config
ncs(config-l3vpn-volvo)# endpoint main-office
ncs(config-endpoint-main-office)# ce-device ce0
ncs(config-endpoint-main-office)# ce-interface GigabitEthernet0/11
ncs(config-endpoint-main-office)# ip-network 10.10.1.0/24
ncs(config-endpoint-main-office)# bandwidth 12000000
ncs(config-endpoint-main-office)# !
ncs(config-endpoint-main-office)# endpoint branch-office1
ncs(config-endpoint-branch-office1)# ce-device ce1
ncs(config-endpoint-branch-office1)# ce-interface GigabitEthernet0/11
ncs(config-endpoint-branch-office1)# ip-network 10.7.7.0/24
ncs(config-endpoint-branch-office1)# bandwidth 6000000
ncs(config-endpoint-branch-office1)# !
ncs(config-endpoint-branch-office1)# endpoint branch-office2
ncs(config-endpoint-branch-office2)# ce-device ce4
ncs(config-endpoint-branch-office2)# ce-interface GigabitEthernet0/18
ncs(config-endpoint-branch-office2)# ip-network 10.8.8.0/24
ncs(config-endpoint-branch-office2)# bandwidth 300000
ncs(config-endpoint-branch-office2)# !
ncs(config-endpoint-branch-office2)# top
ncs(config)# show configuration
It will be great help for me and also others if some-one have some solution how to fix this bug , how to set as-number in l3vpn.
any help will be appreciated.
Samya Ghosh
Germany
yfherzog
Hi Samya,
I believe the documentation might not be inline with the code in the examples directory.
Looking at the YANG code on NSO 4.4.2, I see that the as-number parameter is associated with each endpoint, rather than being a global parameter on the service. This means that each of your endpoints should have this value provided.
so instead of providing this value at this stage, you will have to provided it for each endpoint.
For example,
ncs(config-endpoint-main-office)# as-number 65101
The reason you are getting the error upon commit is because the VPN also includes a mandatory value called route-distinguisher which might be missing from the documentation:
leaf route-distinguisher {
  description "Route distinguisher/target identifier unique for the
  VPN";
  mandatory true;
  type uint32;
so, you'll have to also provide this value - unsigned 32 bits integer
For example, before you provide your endpoint details you can provide value for this field:
ncs(config-l3vpn-volvo)# route-distinguisher 123456
generally speaking, the error you got there suggests that a mandatory value is missing, so you can try using tab completion or '?' in CLI to try to get some hints for the values that are available for you to provide.
Hope that helps,
Yftach
yfherzog
Hi Samya,
For example,
  VPN";
  mandatory true;
  type uint32;
Hope that helps,
Yftach
Dear Yftach,
Thank you for your kind help & real good and right answer.
It's working fine now & I followed your suggestion.
Thanks & Regards
Samya
You're very welcome.
I'm glad it helped!
Yftach
