Proper Allocation of IDs with Resource Manager
jbroniko
Looking for best practices for leveraging the resource manager with an external api call. I am using ISE to populate a list of VLAN Names that i use resource manager to populate the Vlan ID itself based on a location specified. I am running into an issue when redeploying or adding a new location to the service, it will delete the old allocations and then change on redeploy based on return from ISE which is alphabetical. If i add in a location into the service, it will reprocess the existing vlan names and change their original allocation. See code below
Here is an example where it changes the IDs
admin@ncs(config-ise-server-NA)# commit dry-run
cli {
    local-node {
        data  resource-pools {
             +    id-pool VLANS-ID-POOL-Austin {
             +        range {
             +            start 300;
             +            end 400;
             +        allocation Austin-Contractors {
             +            username admin;
             +            allocating-service /ise-server[name='NA'];
             +            redeploy-type default;
             +            request {
             +                sync false;
             -    id-pool VLANS-ID-POOL-Campus {
             -        range {
             -            start 30;
             -            end 40;
             -        allocation Campus-AAdmin {
             -            username admin;
             -            allocating-service /ise-server[name='NA'];
             -            redeploy-type default;
             -            request {
             -                sync false;
             -        allocation Campus-Admins {
             -            username admin;
             -            request {
             -                sync false;
admin@ncs# show resource-pools
NAME                  ID                         ERROR  ID
VLANS-ID-POOL-Campus  Campus-AAdmin              -      36
                      Campus-Admins              -      30
                      Campus-Contractors         -      31
                      Campus-Employees           -      32
                      Campus-IOT                 -      33
                      Campus-Multimedia-Devices  -      -
After Deployment
NAME                  ID                         ERROR  ID
VLANS-ID-POOL-Austin  Austin-Contractors         -      300
                      Austin-Employees           -      301
                      Austin-IOT                 -      302
                      Austin-Multimedia-Devices  -      303
                      Austin-Voice               -      304
VLANS-ID-POOL-Campus  Campus-AAdmin              -      30
                      Campus-Admins              -      31
                      Campus-Contractors         -      32
                      Campus-Employees           -      33
                      Campus-IOT                 -      34
                      Campus-Multimedia-Devices  -      35
                      Campus-Voice               -      36
snovello
From what you share, you made a change that removed the campus-aadmin and campus-admins request. That would  cause the allocated value to be removed/forgotten, then you show the before and after state, and there we see the allocation is still there, so maybe there was a separate commit that caused those requests to be recreated.
If you want a stable values you have to ensure that after each commit the requests are still all in cdb.
If there is a service - its create logic needs to create the requests. you must not have anything like 'if i have not already requested then request'. The requests need to be created every time it runs to keep the stable value.
