Python Usage of maapi_shared functions inside FASTMAP
Maan Al Bachari
Frequent Visitor
Frequent Visitor
Hi Team,
I’m trying to better understand the following:
  • how to use MAAPI functions inside cb_create within service packages, how to define maapi object/session..etc with the existing parameters NCS is passing when the functions is called. I cannot seem to find an examples on that, apologies if I missed it
  • how to use shared functions, such shared_copy_tree..my understanding we need to use the shared methods inside FASTMAP and not the normal ones
I get the following error  when running my code:
Error: Operation was aborted (49): Operation on: /ncs:devices/device{xr1}/config/cisco-ios-xr:class-map{af} failed because: sharedCreate() called outside fastmap
Here is the code snippet:
# -*- mode: python; python-indent: 4 -*-
import ncs
from ncs.application import Service
class ServiceCallbacks(Service):
     @Service.create
     def cb_create(self, tctx, root, service, proplist):
          self.log.info('Service create(service=', service._path, ')')
          srcPE = service.src_device
          srcGePhyPort = service.src_GigE_physint
          destPE = service.dest_device
          destPort = service.dest_interface
          currentClass = 'af'
          m = ncs.maagic.get_maapi(root)
          t = m.attach(tctx.th)
          t.shared_copy_tree('/ncs:devices/device{%s}/config/cisco-ios-xr:class-map{%s}' % (srcPE, currentClass), '/ncs:devices/device{%s}/config/cisco-ios-xr:class-map{%s}' % (destPE, currentClass))
          template = ncs.template.Template(service)
          template.apply('service-template', vars)
To me the above function is inside FASTMAP since it’s in cb_create and using the same root and session transaction handler, what am I missing?
If I pass flag 0 the error I get back is bad formatted or non-existent path, the above works fine with copy_tree but not shared, which is problematic when I want to remove or modify the service
Please excuses any obvious mistakes, my python skills are very rudimental to say the least
Thanks!
Dan, thanks so much for your help! Below is how we made it work:
instead of
t = m.attach(tctx)
we used
t = ncs.maagic.get_trans(root)
no need to redefine a maapi object and attaching to a transaction, just use the existing transaction by root
Thanks!
6 Replies 6
Dan.Sullivan
Hi Maan,
If you don't used share_copy_tree and must copy_tree does it do what you want?
-Dan
Hi Dan,
With copy_tree I can deploy the service and see the class-map in my example being copied from xr0 to xr1, however when I delete the service, it's doesn't remove the class-map from xr1. That's why I thought I need to use shared_copy_tree, as indicated in the documentation:
shared_copy_tree(*args, **kwargs)
FASTMAP version of copy_tree().
Does that make sense?
Thanks!
Hi Maan,
No, that's not really the purpose of 'shared'. In fact, shared sets are used to insure configuration changes can be handled correctly among 1 or more services which share some common configuration items. I'm not sure exactly what is going on with your service. I'll take a closer look.
-Dan
Hi Maan,
Can you post the service modifications once your service is configured?
-Dan
Hi Dan,
admin@ncs(config)# services emergency_pe_migration_mx_mx 123 src-device xr0 src-GigE-physint 0/0/0/1 dest-device xr1 dest-interface 0/0/0/1
admin@ncs(config-emergency_pe_migration_mx_mx-123)# commit dry-run        cli {
    local-node {
        data  devices {
                  device xr1 {
                      config {
             +            cisco-ios-xr:class-map af {
             +                prematch match-any;
             +                match {
             +                    dscp {
             +                        dscp-list ef;
              services {
             +    emergency_pe_migration_mx_mx 123 {
             +        src-device xr0;
             +        src-GigE-physint 0/0/0/1;
             +        dest-device xr1;
             +        dest-interface 0/0/0/1;
Commit complete.
admin@ncs(config-emergency_pe_migration_mx_mx-123)# exit
admin@ncs(config)# no services emergency_pe_migration_mx_mx 123
admin@ncs(config)# commit dry-run
cli {
    local-node {
        data  services {
             -    emergency_pe_migration_mx_mx 123 {
             -        src-device xr0;
             -        src-GigE-physint 0/0/0/1;
             -        dest-device xr1;
             -        dest-interface 0/0/0/1;
This is with tree_copy , pong deleting the service, the changes earlier made on xr1 is not reverted.
Thanks!
instead of
t = m.attach(tctx)
we used
Thanks!
