05-09-2017 07:11 AM - edited 03-01-2019 03:48 AM
Hi team,
I’m using the NSO pnp package and I’m looking for information on how to use the day0 file which is specified in the pnp map.
My CPE only seems to come up with the default CPE.txt file (see attached) which is in the cisco=pnp/cfg directory. If I change the name, no good.
Also, how are these $variables used and where are they specified?
If I add a simple ios command to the CPE.txt file (in packages/cisco-pnp/cfg) (I.e. hostname foo), it doesn’t work.
Any help appreciated. Need to get this working for customer PoC.
John
packages package cisco-pnp
package-version 1.2
description "NED package for supporting Cisco PNP"
ncs-min-version [ 4.2 ]
directory ./state/packages-in-use/1/cisco-pnp
component CiscoPnpSubscriber
application java-class-name com.cisco.pnp.CiscoPnpSubscriber
application start-phase phase2
component pnp-rfs
callback java-class-name [ com.cisco.pnp.PnpRFS ]
oper-status up
05-09-2017 07:11 AM
Hi folks,
I figured it out. I was editing the file in the packages directory but was not doing a packages reload. So the cfg files being actively used were in the
/state/packages-in-use/1/cisco-pnp/cfg directory.
But still, if anyone has info on how the day0 variables work that would be helpful in the future.
05-09-2017 07:12 AM
Following is an example which I tested with PnP package 1.2.
=== CPE.txt
hostname $HOSTNAME
== NSO configuration
pnp map xxxxx
cfg-properties variable HOSTNAME
value router1
05-09-2017 07:12 AM
You may change the name of the day0 file (CPE.txt) by using the cli command pnp map serialnumber day0-file <strng [CPE.txt] >
In adding a PnP device I am using the following config to map a serial number to a PnP device:
If anyone has a better or alternative approach, please let me know.
05-09-2017 07:12 AM
I got the variable piece all working.
Two more questions for the team:
(1) There is command called “pnp reset” which is suppose to restore the device to day—1 configurations. See:
admin@ncs# pnp reset ?
Possible completions:
clean - Restore device to day--1 config.
serial -
Does anyone know how this works? (as it’s not working for me). I have a day—1-config in CPE flash. Also, what is the difference between the “clean” option and just inputing the S/N.
(2) How does the pnp package differentiate between different CPE platforms (which may have different interface numbering, which could be a variable in the day0). I know vMS
handles this, but I’m not sure if they wrote their own service or if this is a feature in the pnp package.
05-09-2017 07:12 AM
For interface map let´s try the following:
admin@ncs# show running-config pnp interface-map
pnp interface-map C19[0-9][0-9]
wan GigabitEthernet0/1
lan GigabitEthernet0/0
pnp interface-map C29[0-9][0-9]
pnp interface-map C39[0-9][0-9]
pnp interface-map C819
lan FastEthernet0
pnp interface-map C891
lan FastEthernet0
pnp interface-map C892
wan GigabitEthernet8
pnp interface-map ISR4351
wan GigabitEthernet0/0/1
lan GigabitEthernet0/0/0
I am trying to figure out how the CSR is presented but I think with a show pnp profile on the CPE we can know it and change accordingly.
There is also a parameter in the pnp interface map named config-restore-file flash:day--1-config
We can try that and or maybe let´s try first adding the interface map, that may be the reason why it is not going back to day--1-config
Hope it heps.
05-09-2017 07:13 AM
BTW the CSR1000V is like this:
pnp interface-map CSR1000V
wan GigabitEthernet1
lan GigabitEthernet2
05-09-2017 07:13 AM
Pnp reset waits for the next time the device connects via PnP, then asks it to “copy flash:day—1-config startup-config” and then reload. There were some versions that we also had inserted a wait in between to make sure that IOS had time to complete saving the config before reloading. Otherwise, we had problem with the config missing some of later parts of the config. It would occasionally take longer than 5 seconds to complete saving the startup-config.
If its not working, enable PNP traces raw and at least look at what is being sent down to the device.
