Reading proplist values in a MAAPI script
tcragg1
Is it possible to read the proplist values for a service inside a MAAPI script? If so, does anyone have a code sample they could share?
u.avsec
You mean reading with a script after provisioning?
If you dump the service instance with ncs_load with flags like '-M -U -o' you will see that there is no convenient 'proplist' node.
If I remember proplist does persist so my guess would be that NSO stores proplist in the private/diff-set gibberish under the instance or somewhere else entirely. First is not useful at all, second would be cool to know if true.
markozagozen
Yes, there is a private/property-list/property list in each service instance:
In [2]: with ncs.maapi.single_read_trans('admin', 'python') as t:
   ...:     s = ncs.maagic.get_node(t, '/foo-service{bar}')
   ...:     for p in s.private.property_list.property:
   ...:         print(p.name, p.value)
k1 v1
k2 v2
You can also access it in the CLI if you unhide fastmap-private.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
