Reload of a single package
edoardo.mileto
 wanted to know if there is a command to run the reload of a single package?
the current version of NCS is 4.6.1
ramkraja
No. Reloading packages involves reloading the fxs files and doing a CDB upgrade, if there are schema changes in the package's yang models. You cannot do it on a per-package basis.
If you don't have yang model changes, and you only have changes to your java/python code, templates etc., then you can do a "redeploy" of a package. You CAN do "redeploy" on a single package, to bring in the new code/templates etc., only from that package. But if you have yang model changes, you have to do a full reload of all packages.
/Ram
ramkraja
/Ram
