Tail-f HCC HaException: wrong response for HA:BESLAVE
equinix
I'm trying to set up a local HA lab which consists of two VMs, each running an NSO instance (system install).
Using the tailf-hcc package and the manual, I attempted to set up the basic example of HA - one master and one slave with failover-master=true.
Both the VMs are reachable via Ping between themselves.
However, when I activate HA (ha commands activate), nothing happens. The master NSO shows the correct state when doing 'show ncs-state ha', with the exception that it doesn't show any connected-slaves.
The slave remains on "ha mode none" and its ncs-java-vm.log shows the following exception:
com.tailf.ha.HaException: wrong response for HA:BESLAVE responded with: {error,25}
    at com.tailf.ha.Ha.checkResponse(Ha.java:297)
    at com.tailf.ha.Ha.beSlave(Ha.java:153)
    at com.tailf.ns.tailfHcc.Cluster.updateLocalNode(Cluster.java:1090)
    at com.tailf.ns.tailfHcc.Cluster.update(Cluster.java:1229)
    at com.tailf.ns.tailfHcc.TcmApp$PeriodicTask.run(TcmApp.java:493)
    at java.util.TimerThread.mainLoop(Timer.java:555)
    at java.util.TimerThread.run(Timer.java:505)
The slave's ncs.log also has the following error:
Failed to connect to master: host is unreachable
Has anyone had this issue?
Best regards,
Gabriel
lmanor
Gabriel,
Since you can ping form device-to-device, the it is likely a firewall (or openstack security) issue not allowing the TCP port required for HA messaging to get thru.
Can you check if port 4570 is being listened for on the Master:
$ netstat -anp | grep tcp
tcp        0      0 0.0.0.0:4570            0.0.0.0:*               LISTEN      -
Also, an easy way to see if a port is blocked or not, is to use telnet.
telnet <ipaddr> portnumber
if it connects, the port is open  (with port 4570 enabled  on 103).
$ telnet 192.168.56.103 4570
Trying 192.168.56.103...
Connected to 192.168.56.103.
Escape character is '^]'.
 �m
CentOS64-17�Z��BSZ8�2~�
telnet>
and a non-connection error like this if the port is not open (with port 4570 disabled  on 103):
[lmanor@CentOS64-2 logs]$ telnet 192.168.56.103 4570
telnet: connect to address 192.168.56.103: No route to host
-Larry
lmanor
Gabriel,
 �m
telnet>
-Larry
Thanks Larry! That was exactly it, it's running smoothly now.
I just opened the port on the master NSO via:
$ sudo firewall-cmd --zone=public --add-port=4570/tcp --permanent
$ sudo firewall-cmd --reload
