RESTAPI to RESTCONF
what would be the equivalent request using RESTCONF
https://localhost:8888/api/running/devices/_operations/sync-from
Yale
I might had a bit of a copy-paste accident...
curl -i -k -u admin:admin https://localhost:8888/restconf/data/devices/sync-from -X POST
HTTP/1.1 200 OK
Server:
Date: Mon, 17 Dec 2018 15:05:57 GMT
Cache-Control: private, no-cache, must-revalidate, proxy-revalidate
Content-Length: 827
Content-Type: application/yang-data+xml
Vary: Accept-Encoding
Pragma: no-cache
<output xmlns='http://tail-f.com/ns/ncs'>
  <sync-result>
yfherzog
Should be:
https://localhost:8888/restconf/operations/devices/sync-from
error 405 :(
HTTP/1.1 200 OK
Server:
Content-Length: 827
Pragma: no-cache
  <sync-result>
post not get ;)
Yale
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
