RESTCONF device notifications doesn't respond
vkarani
I am using this URL:http://localhost:8080/restconf/streams/device-notifications/xml to receive device notifications as stream, but fail to get any response. The request status says 200 OK and request type is GET. Accept type is text/event-stream. I do not et any responses even if a new device is added, deleted or edited. Am I doing something wrong here
vleijon
The stream device-notifications notifies you when a notification is received from a device. The things you are describing here are probably not generating any notifications from the device.
Even if I have a sync from or sync to failure it is not giving any notifications. Do you know a specific scenario to receive a notification that I can test to see if my call is working and giving a response or not?
If the device is a netconf device and sends a notification is the easiest one to get a device notifications.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
