RESTCONF reload packages
Hi all,
trying to reload packages from a restconf call like
https://U:P@host:8888/restconf/operations/packages/reload
but how can i specify force ?
i have tried sending {'force':true} in a json body but that comes back with
"errors": {
"error": [
"error-message": "1: Bad JSON character: '",
"error-path": "/tailf-ncs:packages/reload",
"error-tag": "malformed-message",
"error-type": "application"
thanks
regards
Yale
ramkraja
i have tried sending {'force':true} in json body
'force' is modeled as an empty leaf (in tailf-ncs-packages.yang), and so, it should not have a value.
This should work:
curl -X POST -H "Content-Type: application/yang-data+json" http://U:P@host:8888/restconf/operations/packages/reload -d '{"input": {"force":""}}'
Or this, if you want to use xml:
curl -X POST -H "Content-Type: application/yang-data+xml" http://U:P@host:8888/restconf/operations/packages/reload -d "<input><force/></input>"
/Ram
ramkraja
This should work:
/Ram
Empty leafs are encoded as '"force": [null]' according to RFC 7951 JSON Encoding of Data Modeled with YANG Section 6.9. The "empty" Type
