RESTCONF reload packages
Hi all,
trying to reload packages from a restconf call like
https://U:P@host:8888/restconf/operations/packages/reload
but how can i specify force ?
i have tried sending {'force':true} in a json body but that comes back with
"errors": {
"error": [
"error-message": "1: Bad JSON character: '",
"error-path": "/tailf-ncs:packages/reload",
"error-tag": "malformed-message",
"error-type": "application"
thanks
regards
Yale
ramkraja
i have tried sending {'force':true} in json body
'force' is modeled as an empty leaf (in tailf-ncs-packages.yang), and so, it should not have a value.
This should work:
curl -X POST -H "Content-Type: application/yang-data+json" http://U:P@host:8888/restconf/operations/packages/reload -d '{"input": {"force":""}}'
Or this, if you want to use xml:
curl -X POST -H "Content-Type: application/yang-data+xml" http://U:P@host:8888/restconf/operations/packages/reload -d "<input><force/></input>"
/Ram
ramkraja
This should work:
/Ram
Empty leafs are encoded as '"force": [null]' according to RFC 7951 JSON Encoding of Data Modeled with YANG Section 6.9. The "empty" Type
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
