RESTCONF run action with input args
tsiemers1
I am working on a creating an action that returns some output for a certain show command. I can successfully run the command via the rest api but was wondering if it is possible to do the same via restconf and if their are any advantagaes to doing so.
Also what is the correct way to find a URI path for restconf?
REST api curl:
curl -X POST \
http://localhost:8080/api/running/NDOS:action/_operations/ShowCommands \
-H 'Authorization: Basic dAAAAAAAAAAAAAA==' \
-H 'Content-Type: application/vnd.yang.operation+xml' \
-H 'Postman-Token: AAAAAAAAAAAAAAAAAAAAAAA' \
-H 'cache-control: no-cache' \
-d '<input>
<deviceName>CQ5LAB9K</deviceName>
<showCMD>show l2vpn bridge-domain brief</showCMD>
</input>
Which outputs the results of the custom command and its parser.
<output xmlns='http://example.com/NDOS'>
<result>{'CISCO_TAC': ['TEST_TAC'], 'EVPN_DHN': ['EVPN_2001'], 'Eng': ['LTE_LAB_1', 'LTE_LAB_2']}</result>
</output>
lmanor
Here is a comparison of REST vs RESTCONF for the same action call - notice the difference in the Content Type, as well as the URI path:
REST
curl -X POST -v -T l2lagCreate.json -H'Content-Type: application/vnd.yang.operation+json' -u admin:admin http://127.0.0.1:8080/api/operational/l2lag-api/_operations/l2lag-create-bundle
RESTCONF
curl -X POST -v -T l2lagCreate.json -H'Content-Type: application/yang-data+json' -u admin:admin http://127.0.0.1:8080/restconf/operations/l2lag-api/l2lag-create-bundle
ncs-l2lag-4.7.3$ cat l2lagCreate.json
    "input": [
        "lag-id": "lag-1",
        "customer-id": "Cust-1",
        "description": "Lag-1 for Customer 1",
        "dev": [
            "device": "j0",
            "interface": [
                "name": "xe-1/1/1"
-Larry
5 Replies 5
Hi here is an example using restconf
POST
https://<user>:<pass>@<nso-host>:8888/restconf/operations/devices/device=<nexus device>/live-status/tailf-ned-cisco-nx-stats:exec/any
Headers
Accept application/yang-data+xml
Content-Type application/yang-data+json
Body
{"input":{"args": "show run"}}
Yale
tsiemers1
I was able to get this working after reading the rfc and realizing that it just follows the yang model you create with the action. Also I was sending the input in XML and needed to be JSON in my case.
curl -X POST \
http://localhost:8080/restconf/operations/NDOS:action/ShowCommands \
 -d '{
"input": {
"deviceName": "CQ5CORPLBA41",
"deviceType": "cisco-ios-xr",
"showCMD": "show l2vpn bridge-domain brief"
the example you have posted is using RESTAPI not RESTCONF
Updated. Pasted over the wrong one. The edited command works.
lmanor
REST
RESTCONF
    "input": [
        "lag-id": "lag-1",
        "dev": [
            "device": "j0",
            "interface": [
                "name": "xe-1/1/1"
-Larry
