set timeout for connections to devices
previousqna
Level 5
Level 5
I have an emulated ALU-SR device I am trying to connect to. I know it is pretty slow as it is an emulated device (and the resources on the host machine arent exactly brilliant).
On connect from WebUI I get the following error:
Failed to connect to device ALU-10: connection refused: ned_connect_cli The kexTimeout (20000 ms) expired.
where could I set kexTimeout to a higher value? (I assume kexTimeout is a value relevant to NSO and defines how long to wait inbetween the various connection messages going back and forth between device and NSO!?)
I looked in ncs.conf but that seems to be the wrong place.
previousqna
Level 5
Level 5
t didnt even take delving as deep as ncs.conf
The value can be set for each device in the Web-UI. Default seems to be 20000ms(=20s). New value is to be entered in seconds. See attached image:
previousqna
Level 5
Level 5
