show ... | display json --- for type empty in yang
ben_piret
Hello the community,
We are using types empty in our Yang model and we are a bit surprised by how outcome of those empty types are presented when we display our service in JSON (with the | display json)
For instance, on one example, it gives :
nsoadmin@ncs% show vpnconfig DUMMYVRF | display json
"data": {
"vpnconfig:vpnconfig": [
"name": "DUMMYVRF",
"pedevice": "R10B1930WIN0 R10B4530WIN0 R10B6041WIN0",
"route-distinguisher": 722,
"hubvpns": {"": "management","": "voice","": "publiwin","": "wuh",
"loopback-number": "119",
"clitype": "old",
"importRTin": "200",
"exportmap": "export-public-loop-only-management",
"redistributestatic": "false",
"redistributeconnected": true
The outcome is not very usable for the empty types : in my example it is :
The emtpy types all appear with the key = "" .
Do you thinks that it is normal ?
Kind regards.
Benoit
I tested it this morning in NSO 5.5.1, and the outcome is now good (see the "management": [null],)
Benoit
"data": {
"name": "DUMMYVRF",
"hubvpns": {
"clitype": "old",
9 Replies 9
vleijon
It looks weird, but, what is the yang model for hubvpns?
snipset :
    grouping vpnconfig {
            leaf route-distinguisher {
                description "This is the route distinguisher long explanation";
                tailf:info "route distinguisher";
                type uint32;
                mandatory true;
            leaf global-customer-as {
                tailf:info "Global Customer AS for all sites";
                type uint32;
            container hubvpns {
                leaf own_rd {
                    tailf:info "Is this VPN im-exporting its own RD ?";
                    type empty;
                leaf management {
                    tailf:info "export map export-public-loop-only-management / route-target import 9208:200";
                    type empty;
                leaf internet {
                    tailf:info "Is this VPN spoke from Internet ?";
                    type empty;
                leaf voice {
                    tailf:info "Is this VPN spoke from Voice (SBC) ?";
                    type empty;
                leaf publiwin {
                    tailf:info "Is this VPN spoke from PUBLIWIN ?";
                    type empty;
                leaf wuh {
                    tailf:info "Is this VPN spoke from WUH ?";
                    type empty;
                leaf csoc {
                    tailf:info "Is this VPN spoke from CSOC-HUB ?";
                    type empty;
                leaf loopback-number {
                    tailf:info "VPN Loopback Number in R10 - example: 110 or 486/172.23.177.138";
                    type string {
It looks reversed to me, and own_id is missing for some reason. That doesn't look good to me, I'd expect own_id:'', management:'' or something like that.
ok, I also thought that it was reversed in the json outcome - it should be : "management" : "" etc.
I will raise a SR with the TAC
Benoit
Feedback from the case :
The reported issue has been fixed:
  - cli: When showing an empty leaf in JSON format, with the pipe command
    "display json", the output had the wrong format. This has been fixed.
The change was/will be included in below and later versions:
  * nso-5.2.6
  * nso-5.3.4
  * nso-5.4.3 (09-Mar-2021)
  * nso-5.5.1 (09-Feb-2021)
  * nso-5.6
snovello
Hello ,
‘display json’ is sometimes used to create examples of the json that is used from the REST API of NSO. To make it easier to copy paste that output directly I think it would be useful for NSO to output using the encoding defined in RFC 7951 – ‘JSON Encoding of Data Modeled with Yang’ which is the encoding used in RESTCONF. In that encoding an empty leaf foo, looks like “foo”:[null], so an array containing null.
You are right - it's B/W in the RFC §6.9.
I will highlight this in the SR case so that it can be corrected in compliance with the RFC
Benoit
For those of you who have "deep access" to TAC SR, it's :SR # 690615369
Benoit
Benoit
"data": {
"name": "DUMMYVRF",
"hubvpns": {
"clitype": "old",
