Subscriber pushes //private// keypaths through regex filter
u.avsec
Hey,
I have a subscriber sitting in a non service PACKAGE that is monitoring ANOTHER_PACKAGE which is a service package with a top list of devices, where their names are the key. Subscriber is registered on /ANOTHER_PACKAGE/devices
I don't want to act on everything that is going on in ANOTHER_PACKAGE; only if device is deleted, or if a particular enum node (/ANOTHER_PACKAGE/devices{rtr}/onboarding/external-systems/rfs-nso-systems) under each device is changed. So I set up a regex filter to catch what I want to act upon. It looks something like this:
def iterate(self, keypath, operation, oldval, newval, state):
    """Filter subscription."""
    keypath = str(keypath)
    self.log.info(keypath)
    if match('/ANOTHER_PACKAGE/devices{.*}/onboarding/external-systems/rfs-nso-systems$', keypath) and operation == ncs.MOP_VALUE_SET:
        state.append([operation, keypath])
        return ncs.ITER_RECURSE
    if match('/ANOTHER_PACKAGE/devices{.*}$', keypath) and operation == ncs.MOP_DELETED:
    state = []
 When I run it though, NSO does something which I understand where it is coming from and why but not how it passes the regexes. Following is a self.log.info print of a state attribute in post_iterate:
[[4, '/ANOTHER_PACKAGE/devices{rtr}/onboarding/external-systems/rfs-nso-systems'],
[2, '/ANOTHER_PACKAGE/devices{rtr}/onboarding/external-systems/rfs-nso{rfs-58}'],
[2, '/ANOTHER_PACKAGE/devices{rtr}/private/device-list{rfs-58}'],
[2, '/ANOTHER_PACKAGE/devices{rtr}/private/ned-id-list{cisco-nso-nc-5.8:cisco-nso-nc-5.8}'],
[4, '/ANOTHER_PACKAGE/devices{sw}/onboarding/external-systems/rfs-nso-systems'],
[2, '/ANOTHER_PACKAGE/devices{sw}/private/device-list{rfs-58}'],
[2, '/ANOTHER_PACKAGE/devices{sw}/private/ned-id-list{cisco-nso-nc-5.8:cisco-nso-nc-5.8}']]
 I checked the regexes, they work as intended.
I tried to put ITER_STOP on the returns, which fixes the issue for one device per transaction but if multiple devices get modified in the same transaction, the second device + n won't get processed by the subscriber.
Creating devices from scratch and deleting them completely works fine. Only if I change that enum on //rfs-nso-systems to a particular value which causes the //rfs-nso leaf-list to be deleted in the process, then I get the above output.
Help
u.avsec
I ended up ditching regex and did this:
if 'rfs-nso-systems' in keypath:
if keypath.count('/') == 2 and operation == ncs.MOP_DELETED:
state = []
Now it is fine, and faster too, I found out. Looks a bit MacGyverish though.
I don't know how those private keypaths got in, perhaps bug in re or my lack of knowledge regarding the module. It would be interesting to know.
Hi, is match part of the re python library or something else? missing your import statement.
It is re, yes
EDIT: I just realised my initial delete regexe was too lax. The reason I didn't figure it out was because there was a not very obvious typo in the test string I was testing with. :facepalm:
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
