system install blank cli
ryan-hitch
Level 4
Level 4
I am doing my first nso system install for a production environment. After software installation (ncs 4.5.2), I add a user to the ncsadmin group, however when I login to ncs_cli the only option is "exit". What am I doing wrong here? I have not had this issue with local installs for development. I hate having to ask simple questions like this, but I just can't seem to find anything in the documentation.
Here are the steps that I have followed:
[user@nso ~]$ sudo sh nso-4.5.2.linux.x86_64.install.bin --system-install
[user@nso ~]$ sudo groupadd ncsadmin
[user@nso ~]$ sudo usermod -a -G ncsadmin user
[user@nso ~]$ source /opt/ncs/ncs-4.5.2/ncsrc
[user@nso ~]$ sudo systemctl start ncs
[user@nso ~]$ ncs_cli
user connected from 192.168.0.172 using ssh on nso.auto.lab
user@ncs> ?
Possible completions:
exit - Exit the management session
user@ncs>
Ryan,
I see the same behavior when following your approach above.
It seems that the new group added 'ncsadmin' does not get recognized by NSO within the current shell (groups in current shell does not get updated with new group), see ncs audit.log output.
If you log into a new shell then the groups gets update to include 'ncsadmin' and NSO will also see the new group applied to user1:
[user1@CentOS7-1 ~]$ sudo usermod -a -G ncsadmin user1
[user1@CentOS7-1 ~]$ groups
user1
[user1@CentOS7-1 ~]$ groups user1
user1 : user1 ncsadmin
[user1@CentOS7-1 ~]$ sudo systemctl restart ncs
[user1@CentOS7-1 ~]$ ncs_cli
user1 connected from 127.0.0.1 using console on CentOS7-1
user1@ncs> ?
user1@ncs>
user1@ncs> exit
==> /var/log/ncs/audit.log <==
<INFO> 3-Jan-2018::16:17:57.350 CentOS7-1 ncs[9708]: audit user: user1/47 assigned to groups: user1
==> Log into a new shell:
[user1@CentOS7-1 ~]$ su user1
Password:
user1 ncsadmin
user1@ncs> ?
  clear      - Clear parameter
  compare    - Compare running configuration to another configuration or a file
  configure  - Manipulate software configuration information
  describe   - Display transparent command information
  file       - Perform file operations
  help       - Provide help information
  id         - Show user id information
  monitor    - Real-time debugging
  ping       - Ping a host
  ping6      - Ping an ipv6 host
  quit       - Exit the management session
  request    - Make system-level requests
  script     - Script actions
  set        - Set CLI properties
  set-path   - Set relative show path
  show       - Show information about the system
  source     - File to source
  switch     - Change CLI style
  top        - Exit to top level and optionally run command
  traceroute - Trace the route to a remote host
  up         - Exit one level of configuration
user1@ncs>
<INFO> 3-Jan-2018::16:20:24.552 CentOS7-1 ncs[9708]: audit user: user1/48 assigned to groups: ncsadmin,user1
-Larry
ryan-hitch
Level 4
Level 4
Argh. A reboot appears to have cleared this up, not sure why that would matter as I had stopped and started the ncs service repeatedly.
Ryan,
user1
user1@ncs> ?
user1@ncs>
user1@ncs> exit
Password:
user1 ncsadmin
user1@ncs> ?
  ping       - Ping a host
user1@ncs>
-Larry
