tailf-hcc Deployment Guide
ryan-hitch
Level 4
Level 4
Can anyone point me to the tailf-hcc Deployment Guide? I just downloaded the most recent posted release for NSO 4.5, which appears to be ncs-4.5.3-tailf-hcc-project-4.3.2.signed.bin. There is a doc directory in the package, but no complied Deployment Guide and when I try to run a 'make' from this directory it seems to be looking for 'tailf-doc' which is not present to build the documentation.
Thanks in advance.
That is correct, you should have a pdf in the doc directory, you should not have to build it yourself.
May I ask where you got the binary from?
Attached is the documentation for Tailf HCC 4.3.2.
BR,
Johan
taylrjones
Any update to this? I am also having this problem.
yfherzog
Seems to me as a documentation bug on this build.
As far as I know, you should have a tailf_hcc.pdf pre-built under either the project main doc directory or under the tailf-hcc package directory, under doc/output.
I'd suggest opening a TAC case.
In the meantime, you can get the same document from another build of the same package version (e.g. the one for NSO 4.7).
BR,
Johan
