Template foreach not working as expected
Steven Li
Community Member
I have created service model to test template <?foreach {expression}?>...<?end?>:
The service yang:
    list ST{
      key "ovc";
      uses ncs:service-data;
      ncs:servicepoint "ST-servicepoint";
      leaf ovc {
        type string;
	    tailf:info "ST service ID";
        mandatory true;
      leaf device {
        type leafref {
            path "/ncs:devices/ncs:device/ncs:name";
        tailf:info "Device name";
        mandatory true;
      leaf interfaceId {
        type string;
        tailf:info "Interface ID";
      list unit {
          key "logicalInterfaceId";
          leaf logicalInterfaceId {
            type string;
            tailf:info "Logical interface ID";
Config template:
<config-template xmlns="http://tail-f.com/ns/config/1.0"
                 servicepoint="ST-servicepoint">
    <devices xmlns="http://tail-f.com/ns/ncs">
       <device>
         <name>{/device}</name>
         <config>
           <configuration xmlns="http://xml.juniper.net/xnm/1.1/xnm">
             <interfaces>
               <interface>
                 <name>{/interfaceId}</name>
                 <?foreach {/unit}?>
                 <unit>
                   <name>{/unit/logicalInterfaceId}</name>
                   <description>{/unit/logicalInterfaceId}</description>
                   <vlan-tags>
                     <outer>{/unit/logicalInterfaceId}</outer>
                     <inner>{/unit/logicalInterfaceId}</inner>
                   </vlan-tags>
                   <encapsulation>vlan-ccc</encapsulation>
                 </unit>
                 <?end?>
               </interface>
             </interfaces>
           </configuration>
         </config>
       </device>
    </devices>
</config-template>
Test data:
   "ST:ST":
        "ovc": "ST001",
        "device": "j2",
        "interfaceId": "xe-0/0/2",
        "unit": [{"logicalInterfaceId":"1"},
                 {"logicalInterfaceId":"2"},
                 {"logicalInterfaceId":"3"}]
Config result:
admin@ncs# show running-config devices device j2 config junos:configuration interfaces interface xe-0/0/2
devices device j2
 config
   unit 1
    description   123
    encapsulation vlan-ccc
    vlan-tags outer 123
    vlan-tags inner 123
   unit 2
    description   123
    vlan-tags outer 123
    vlan-tags inner 123
   unit 3
    description   123
    vlan-tags outer 123
    vlan-tags inner 123
The above result is not what I expected.
The expected result is:
devices device j2
 config
   unit 1
    description   1
    vlan-tags outer 1
    vlan-tags inner 1
   unit 2
    description   2
    vlan-tags outer 2
    vlan-tags inner 2
   unit 3
    description   3
    vlan-tags outer 3
    vlan-tags inner 3
What is wrong?
ramkraja
                 <?foreach {/unit}?>
                 <unit>
                   <vlan-tags>
                   </vlan-tags>
                 </unit>
                 <?end?>
Your foreach expression is "/unit". This means that the context for xpath expressions used within the foreach expression will be at the "unit" list. So, inside the foreach expression, you should use only the key leaf's name to refer to the key value in the service model - ie., just
<name>{logicalInterfaceId}</name>
instead of
The way you have it now, it will get the key values of *all* the instances, and concatenate them to get the value for the expression. This is what you see.
Pro Tip: You can use the "debug template" pipe flag to see exactly what is done when applying a template. ie., do "commit dry-run | debug template" or "commit | debug template", and you can follow what NSO does when you apply a template.
/Ram
ramkraja
                 <?foreach {/unit}?>
                 <unit>
                   <vlan-tags>
                   </vlan-tags>
                 </unit>
                 <?end?>
instead of
/Ram
Thanks, this helped me a lot.
