Unable to add devices in NCS CLI
Vijay1606
I'm trying to add a device through NCS CLI after reloading the NED packages. However, the CLI doesn't accept my input and I'm getting an incomplete path error. Getting the same error with J login CLI. This is for NSO 5.3 system install. The NED packages are copied to /var/opt/ncs/packages/, /opt/ncs/packages/ and /opt/ncs/ncs-5.3/packages directories. After reloading the packages, I'm getting an incomplete path error shown below. Please help with this error.
admin@ncs# packages reload force
reload-result {
package alu-sr-cli-8.4
result true
reload-result {
package cisco-ios-cli-6.44
result true
reload-result {
package custom_ospf
result true
reload-result {
package juniper-junos-nc-4.5
result true
admin@ncs#
System message at 2020-09-18 18:36:50...
Subsystem stopped: ec_junos_ext_vlan_hook_daemon
admin@ncs#
Subsystem stopped: ncs-dp-54-cisco-ios-cli-6.44:IOSDp
admin@ncs#
Subsystem stopped: ncs-dp-53-alu-sr-cli-8.4:AluSrDp
admin@ncs#
Subsystem started: ec_junos_ext_vlan_hook_daemon
admin@ncs#
Subsystem started: ncs-dp-55-alu-sr-cli-8.4:AluSrDp
admin@ncs#
Subsystem started: ncs-dp-56-cisco-ios-cli-6.44:IOSDp
admin@ncs(config)# devices device test1
syntax error: incomplete path
admin@ncs# show packages package package-version
PACKAGE
NAME VERSION
alu-sr-cli-8.4 8.4.5
cisco-ios-cli-6.44 6.44
custom_ospf 1.0
juniper-junos-nc-4.5 4.5.21
Than
aelganzo
1- what the Possible completions after the device name  test1 ?
2- what the output of  #show packages package oper-status
Hi @aelganzo ,
 There are no Possible completions after the device name  test1
admin@ncs# show packages package oper-status
packages package L2Vpn
oper-status up
packages package alu-sr-cli-8.4
oper-status up
packages package cisco-ios-cli-6.44
oper-status up
packages package juniper-junos-nc-4.5
oper-status up
