Unable to get the same results, navigate in Maagic with ncs_pycli
Hello, I am trying to access nso service attributes with ncs_pycli to write a code in python.
This works and I can navigate to all services:
In [12]: for i in root.ncs__services:
...: print(i)
ncs:global-settings
ncs:properties
ncs:customer-service
ncs:service
ncs:logging
ncs:commit-queue-notifications
ncs:plan-notifications
device-provisioning:device-provisioning
leaf-sw:leaf-sw
sbc-vpn:sbc-vpn
vpn:vpn
ncs:check-sync
and for vpn service works as well, I can retrieve the vrf id:
In [4]: for i in root.ncs__services.vpn:
...: print(i.vrf)
555
sbc-vpn service is not recognized and I can not access any attribute, has the same service skeleton(python):
In [5]: for i in root.ncs__services.sbc-vpn:
...: print(i.vrf-id)
AttributeError Traceback (most recent call last)
/usr/local/lib/python3.6/site-packages/ncs_pycli/ncs_pycli.py in <module>
----> 1 for i in root.ncs__services.sbc-vpn:
3 print(i.vrf-id)
~/nso-5.6.1/src/ncs/pyapi/ncs/maagic.py in __getattr__(self, name)
476 return child
477 else:
--> 478 super(Node, self).__getattribute__(name)
479
480 def __setattr__(self, name, value):
AttributeError: 'Container' object has no attribute 'sbc'
In [6]:
rhinst001
Level 4
Level 4
Hyphen is not a valid character in a python variable, so you need to use underscore in its place when you're using maagic:
for i in root.ncs__services.sbc_vpn:
    print(i)
rhinst001
Level 4
Level 4
    print(i)
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
