Understanding NSO api and its usage
smadappa
Community Member
I am struggling to explore NSO api and code myself when I don't have a prior sample available thru documentation or example. Can anyone please help on what is the right way of exploring the api and its usage.
For eg:- I got to know that maapi single_write_trans apply() method can take an optional argument 'flags' which control the behavior of transaction during commit based on the flag values.
So my question is..If I don't know this prior, how do I find it myself that apply() can take optional arguments such as flags and what are all the flags values? (Note: I am using Python api).
Shameer
Dan.Sullivan
Hi Shameer,
First off you can check the doc directory right below the NSO installation. Have you also check the examples.ncs directory which has quite a bit of examples?
-Dan
