05-10-2018 02:12 AM - edited 03-01-2019 04:09 AM
Hi All,
When I try to upgrade NSO from 4.3.1 to 4.6.1, I met below issues. Could some help?
Below is the ned packages I used:
-rwx------. 1 ocp ocp 2567778 May 10 02:47 ncs-4.6.1-cisco-asa-5.10.6.tar.gz
-rwx------. 1 ocp ocp 40034343 May 10 02:48 ncs-4.6.1-cisco-ios-5.9.3.tar.gz
-rwx------. 1 ocp ocp 25106824 May 10 02:48 ncs-4.6.1-cisco-iosxr-6.6.2.tar.gz
-rwx------. 1 ocp ocp 2064444 May 10 08:50 ncs-4.6.1-citrix-netscaler-3.0.23.tar.gz
-rwx------. 1 ocp ocp 2187543 May 10 02:47 ncs-4.6-tailf-hcc-4.3.2.tar.gz
And below is the error info:
May 10 09:06:30 nso-master systemd[1]: Starting LSB: NCS...
-- Subject: Unit ncs.service has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit ncs.service has begun starting up.
May 10 09:06:30 nso-master ncs[2507]: - Starting NCS vsn: 4.6.1
May 10 09:06:30 nso-master ncs[2507]: - Loading file confd.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file ietf-yang-types.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file ietf-inet-types.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file confd_cfg.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file config.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_notification.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_actions.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file yang.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_transactions.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_partial_lock.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_tailf_commit.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_forward.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_inactive.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf_netconf.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file ietf_with_defaults.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file cli-builtin.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file ietf-restconf.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file ietf-yang-patch.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf-ncs-config.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_ncs.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf-netconf-extensions.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf-netconf-query.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file netconf_rollback.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf-rest-query.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file tailf-rest-error.fxs
May 10 09:06:30 nso-master ncs[2507]: - Loading file /etc/ncs/ncs.conf
May 10 09:06:30 nso-master ncs[2507]: - Consulting daemon configuration file /etc/ncs/ncs.conf
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/citrix-netscaler/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-iosxr/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-ios/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/ciap-upservice/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/ciap-servicereconciliation/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/ciap-dialpeer/package-meta-data.xml
May 10 09:06:30 nso-master ncs[2507]: - Loading file /var/opt/ncs/state/packages-in-use/1/ciap-acl104/package-meta-data.xml
May 10 09:06:47 nso-master ncs[2501]: Starting ncs: CDB: Upgrade failed: Upgrade transaction failed to validate: /ncs:devices/device{NS}/device-type/generic/ned-id is not configured
May 10 09:06:47 nso-master ncs[2501]: Daemon died status=13
May 10 09:06:47 nso-master systemd[1]: ncs.service: control process exited, code=exited status=13
May 10 09:06:47 nso-master systemd[1]: Failed to start LSB: NCS.
-- Subject: Unit ncs.service has failed
-- Unit ncs.service has failed.
-- The result is failed
05-14-2018 01:51 PM
Looks like you are missing a NED
-Dan
