Showing results forĀ
Search instead forĀ
Did you mean:Ā
Upgrading callpoints on yang
spudukko
I have a query. We have a callpoint on yang leaf which has a validation callpoint which is being moved for upgrade scenario . How does one migrate the call point on package reload . As the old data is getting validated at phase 0 , the code  errors out as call-point not found.
This is the approach currently I am trying to follow in upgrade script. Is the approach correct ? What is the ideal approach?  I understand that there is no validate option .
       Socket ctrl_socket= new Socket("localhost",Conf.NCS_PORT);
       final Dp dp = new Dp("server_daemon",ctrl_socket);
      dp.registerAnnotatedCallbacks(new Myvalidator());
       dp.registerDone();
       Thread dpTh = new Thread(new Runnable() {
           public void run() {
               try {
                   while (true) dp.read();
               } catch (Exception e) {
                   e.printStackTrace();
                   return;
       dpTh.start();
Appreciate all the help.
0 Replies 0
