Using deref() to pull interfaces from the CDB after indicating a device
Andrew Horrigan
I am attempting to use deref() to generate a list of interfaces based on a previously selected device in the same service model.  Once the users select a device (which is another leafref), I want to pull the list of interfaces from the CDB and present them to the user for a second leafref using deref().  However, I am unable to get past a "make" because it keeps on resulting in:
error: bad argument value "deref()", should be of type path-arg
Obviously, either my deref is not correct or I am trying to pull the information from the wrong spot in the CDB.  Here is the relevent part of the service model:
module cspOnboard {
  namespace "http://example.com/cspOnboard";
  prefix cspOnboard;
  import ietf-inet-types {
    prefix inet;
  import tailf-common {
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Service to initiate VNF spinup on CSP2100";
  revision 2017-08-28 {
    description
      "Initial revision.";
  augment /ncs:services {
  list cspOnboard {
    description "This is the CSP2100 VNF Onboarding Service";
    key name;
    leaf name {
      tailf:info "Unique Service Name";
      tailf:cli-allow-range;
      type string;
    uses ncs:service-data;
    ncs:servicepoint cspOnboard-servicepoint;
    leaf csp-device {
      type leafref {
        path "/ncs:devices/ncs:device/ncs:name";
      mandatory true;
    // Service Instance onboard multiple VNFs
    list vnf-onboard {
      leaf vnic1-int {
        type leafref {
          path "deref(../csp-device)/ncs:config/";
        mandatory true;
      leaf vnic1-vlan {
        type uint16 {
            range 0..4096;
In the CDB, I am trying to get this information available to the user as options:
admin@ncs# show running-config devices device SAE-CSP1 config pnic
config
  pnic enp10s0
   type ethernet
   sr-iov totalvfs 0
   lldp enabled
  pnic enp129s0f0
   type      ethernet
   member_of po21
   sr-iov totalvfs 63
   lldp      enabled
  pnic enp129s0f1
   type      ethernet
   member_of po21
   sr-iov numvfs 0
   sr-iov totalvfs 63
   sr-iov switchmode veb
   lldp      enabled
Could someone instruct me on where I am going wrong?  Thanks!
The syntax, as Ryan indicated, should be a path to the complete list that you want to filter from, and then a must statement that will filter on that list.
My only comment would be that in your statements instead of pnics:pnic, you'd probably need to use pnics:pnic/pnics:name or pnics:id (or whatever is the name of the key leaf. I don't know the model, but this needs to point to the leaf under the pnic list which is the key of that list).
Yftach
9 Replies 9
ryan-hitch
Level 4
Level 4
Looks similar to what I was just trying to do here constrain list of devices associated with site
Try something like this:
leaf vnic1-int {
  type leafref {
    path "/ncs:devices/ncs:device/ncs:config/ncs:pnic";
  must "current() = deref(current()/../csp-device)/../ncs:config/ncs:pnic";
My issue, is that no matter configuration (even the suggestion above), I cannot successfully issue a make.  Looking back, my explanation was a little convoluted, so let me try this again:
I am trying to pull the pnics into the service model as shown in the following information:
admin@ncs# show running-config devices device sae-csp2 config pnic
config
  pnic enp10s0
  type ethernet
  sr-iov totalvfs 0
  lldp enabled
  pnic enp129s0f0
  type ethernet
  sr-iov numvfs 63
  sr-iov totalvfs 63
  lldp enabled
In the existing YANG model, I ask them for their csp-device:
    leaf csp-device {
      type leafref {
      mandatory true;
My goal is to take their “answer” for csp-device and then use that to pull the right configs from the NSO CDB.
I have tried this:
      leaf vnic1-int {
        type leafref {
          path "/ncs:devices/ncs:device/deref(../csp-device)/ncs:config/pnics:pnic";
And this:
      leaf vnic1-int {
        type leafref {
          path "deref(../csp-device)/ncs:config/pnics:pnic";
However, neither is working.  Whenever I try to compile the service model, I get the following error:
[root@sae-nso src]# make
mkdir -p ../load-dir
mkdir -p java/src//
make: Warning: File `yang/cspOnboard.yang' has modification time 209 s in the future
/root/nso-4.5/bin/ncsc  `ls cspOnboard-ann.yang  > /dev/null 2>&1 && echo "-a cspOnboard-ann.yang"` \
              -c -o ../load-dir/cspOnboard.fxs yang/cspOnboard.yang
yang/cspOnboard.yang:109: error: bad argument value "deref(../csp-device)/ncs:config/pnics:pnic", should be of type path-arg
make: *** [../load-dir/cspOnboard.fxs] Error 1
[root@sae-nso src]#
Thoughts?  Thanks!
Yftach
Thanks for the advice.  I was using pnics:pnic because of the way it was displayed in the NSO GUI, but honestly, I am not entirely sure how to reference this in the xpath ...
I have the following, but now I am getting a namesapce error:
    leaf vnic1-pnic {
      type leafref {
path "/ncs:devices/ncs:device/ncs:config/pnics:pnic/pnic:name";
      must "current() = deref(current()/../csp-device)/../pnics:pnic/pnic:name";
make: Warning: File `yang/cspOnboard.yang' has modification time 125 s in the future
yang/cspOnboard.yang:109: error: XPath error: Invalid namespace prefix: pnics
yang/cspOnboard.yang:111: error: XPath error: Invalid namespace prefix: pnics
Here is what I am trying to access in the GUI:
And here is the model:
module pnic {
  namespace "http://www.cisco.com/ns/test/pnic";
  prefix pnic;
      prefix tailf;
  organization "Cisco Systems, Inc.";
  revision 2015-04-30 {
      description "Initial release";
  container pnics {
    tailf:cli-drop-node-name;
    list pnic {
      key name;
Have you imported the pnic module in the cspOnboard module?
e.g. something like:
import pnic {
prefix pnic;
I have not ... because it is part of another NED.  I did try to put the import prefix into the yang, but it cannot find the module.
If it wasn't obvious, I am a bit new to this!
Just to update the thread here, I was able to get my deref() working (with some help) by making a few different changes.
Here is the final, working code:
    leaf vnic1-pnic {
      type leafref {
path "deref(../../csp-device)/../ncs:config/pnic:pnics/pnic:pnic/pnic:name";
The two other things necessary were importing the pnic module and adding a PATH to the Makefile in /src, pointing to the location of the YANG files for the CSP NED being used for the pnic information.
YANGPATH += ../../csp2100-netconf/src/ncsc-out/modules/yang
I am not running into a different, but semi-related problem.  I am using the same method to grab a different list of items from the same CSP, and for w/e reason, NSO is only displaying 1 option, as opposed to the 2 listed on the box.
CSP CLI:
resource csp-2100
ip_address          10.1.60.22
netmask             255.255.255.0
default_gw          10.1.60.1
num_service         8
rsyslog_udp_only    false
log_severity        info
storage SVS-NFV-NFS1
  storagetype            nfs
  storage_space_total_gb 200.0
  server_ip              10.1.60.251
  server_path            /var/SVS-NFV-NFS1
storage SAE-NFS
  storagetype            nfs
  server_path            /var/SAE-NFS
My YANG looks very similar to the one used for the pnics:
      leaf nfs-name {
        type leafref {
      path "deref(../../csp-device)/../ncs:config/resource:resources/resource:resource/resource:storagelist/resource:storage/resource:mount_name";
However, this is what shows up in the GU for pnics vs nfs-name:
Screen Shot 2017-12-17 at 9.50.24 AM.pngScreen Shot 2017-12-17 at 9.50.17 AM.png
Could you enable NETCONF tracing for the device, run sync-from and share the resulting log with me?
The device was sync'd properly =(  Sorry for the confusion!
